Captain General Posted October 20, 2015 Share Posted October 20, 2015 I doing a Baneblade in an urban gray mix camo pattern. What wash color (colors) should I use to bring out detail without "washing"/muting out the gray? CG Link to comment https://bolterandchainsword.com/topic/315106-urban-camo-wash/ Share on other sites More sharing options...
GrandMagnus Posted October 20, 2015 Share Posted October 20, 2015 If I understood that correctly I suggest you apply a black or even blue wash depending on the type of shade you might want into only the recesses. That way the grey won't be obscured and the details will pop out. I hope I explained that correctly :) Link to comment https://bolterandchainsword.com/topic/315106-urban-camo-wash/#findComment-4201948 Share on other sites More sharing options...
Father Mehman Posted October 20, 2015 Share Posted October 20, 2015 If you want your Baneblade to look like it's seen some wear and tear or has just been driven around, I'd suggest using Agrax Earthshade and Typhus Corrosion in the recesses like GrandMagnus said. It'll make it look like road grime has gotten in between armour plates and around the rivets. Link to comment https://bolterandchainsword.com/topic/315106-urban-camo-wash/#findComment-4201971 Share on other sites More sharing options...
Lucien Eilam Posted October 20, 2015 Share Posted October 20, 2015 An oil wash of MIG Productions' Starship Filth would probably be perfect. Link to comment https://bolterandchainsword.com/topic/315106-urban-camo-wash/#findComment-4201981 Share on other sites More sharing options...
Captain General Posted October 20, 2015 Author Share Posted October 20, 2015 Thanks for the help. CG Link to comment https://bolterandchainsword.com/topic/315106-urban-camo-wash/#findComment-4202209 Share on other sites More sharing options...
