Best of the Cerastus Chassis?
Brother Heinrich
Hey all,
Just looking for an opinion on what (in your opinion) is the best of the Ceratus Knight chassis. After reading the rules for the Atropos I'm inclined to call it the champ seeing as it has a Str-D Melee Weapon, a 8" Range Str-D weapon, and a 36" range Str8 Ap2 Armourbane, Concussive pie plate weapon. Additionally it's ion shield acts like a flare shield and it has blessed autosimulcra.
My next choice would be a Knight Acheron, just for looks, but I'd love to hear your thoughts everyone :)
https://bolterandchainsword.com/topic/315346-best-of-the-cerastus-chassis/
All of them, with the Castigator possibly being the weakest of the bunch, are strong choices, imo, each with a different job in mind:
Atrapos: Killing the BIGGEST Nasties. Barring the God-Machine that is the Warlord.
Lancer: Killing Big Nasties
Acheron: Burninating Fools and Ripping up Armor
Castigator: Dealing with a single, large horde.
Use em to fill a particular role in an army.
To me, the best is the Atrapos followed Closely by the Acheron.
Atropos, by a mile.
FW is giving us a pick and choose weapons for Seneschals in the next book, IIRC, so that will be the true winner.
Is this another tidbit from the recent Open Day? Wow, I'm very excited for this. Here's hoping they even go so far as to add some extra resin arm options like electro-lashes or something.
On topic, it's hard to go wrong with a Cerastus chassis. They're all good at what they do. The Atrapos is the easiest to drop into a list and expect it to perform though, which was a seat held by the Acheron until they released that Mechanicum monster.
Remember that technically the Knights aren't LoW choices for Legions anymore... Just Mechanicum and allied as Questoris. But I bet your gaming group is cool with it. I don't see a problem anyway
If you have a main legion force, can you take an allied AdMech force to get one as a LoW? Or does it specify that you can only take a cerastus knight if your primary detachment is AdMech?
I just feel that using two Knights (by allying) is a bit cheesy in beer and pretzels play.
Actually funny enough the Atrapos is the first Knight that has it specifically written in the rules that it can be a simple Lord of War choice. So technically it's the only Knight that can be singularly taken alongside Legion forces in the LoW slot.
Imagine a Seneschal with two Warden Avenger Bolt Cannons and the Atropos Shield. Goodbye everything that isn't a terminator or vehicle.
I'm conflicted; on the one hand, that's awesome. On the other, I hope the Seneschal options aren't super abusable or come at a reasonable cost. I trust FW enough that it'll probably be fine though.
The latter. Your LoW is bound to your primary detachment in the main AoD force org chart.
And two knights is nothing! I was looking into it and if they keep the Gallant the same price for the Questoris list, you can fit some 6 Knights into ~2250 by spamming 290 pt Aspirant Gallants tongue.png
There are two boxes on the Atrapos rules pdf. The first is for AoD, the second is for 40k. AoD box only allows it as a LoW for Mechanicum or as part of a Questoris list unfortunately sad.png Again, I wouldn't be fussed if someone ran it as a LoW for Legions anyway, but I wouldn't want anyone reading this to get confused if they try and bring it to a competitive scene and get turned down.
edit: reading through those boxes I've just realized the Atrapos is more easily available in 40k than 30k. Wat?
Actually there is a Limit on how many Aspirants you can have in a Questoris Army, thankfully tongue.png But you can have quite a few of them.
Ie: You cannot have more Aspirants than you have of any other Rank
I'm well aware :P Otherwise I'm pretty sure you could get more than 6 nights into 2250. The list I was screwing around with had 3 Gallant Aspirants, a Crusader Arbalester... Seneschal Atrapos and something else. It was an Acheron with the rank that gives D6 wall of death instead of D3. That's assuming they use the same points for stuff as Codex: Imperial Knights, which they may well not...
Ah I see
My MO for Knight lists is to abuse the Crap out of Arballester and Perceptor (The rank you're talking of).
Usually is @ ~2500pts
Seneschal -
At this point, an Atropos
Troops -
Martial - <insert cheapest possible knight>
Elites -
Perceptor - Acheron
+1 if I have the Points
Heavy Support -
Arballester - Styrix
Fast Attack -
Uhlan - Lancer
I can usually fit 5/6 Knights @ 2.5k
Where Spamming Aspirants gives you quantity, this goes for TAC Type Deal. Planes on the Way? Skyfire + Tankhunter + Interceptor Styrix' with S8 Shooting makes short work oh them.
Deep Striking Infantry? Intercepting Hellstorm Ap3 Flamers!....and anything else inside the Interceptor Bubble.
Horde Problems, Such as Levy Squad Spam? CHOOM and Hellstorm Templates to the rescue!
Hit & Run Knight Lancer for Slingshot Shenanigans!
Seneschal Atrapos because its too good not to do.
Hesh and I made a good case about making the Uhlan an Atrapos. I mean the ionic flare shield eats a lot of shots to mitigate the reduced armor, and the scout helps it a lot since its weapons are so close ranged.
You won't have to worry about the 24" range limit, as you'll scout 12", and then have a first turn move of 12" as well.
Failing that, it's make a great Seneschel because it's ionic flare shield takes it to god tier.
Atropos, by a mile.
Yep.
I have no idea what its rules are, and I couldn't care less. It's beautiful. It's the Magaera of the Cerastus-patterns.
It certainly is a stunning Knight. I invested in a Warden literally the week before it was unveiled and I'm kicking myself. My Knightly budget is spent for the time being :-P
I really like the Atropos except for the head and shoulderpads, they're not bad, but I just want the Lancer Shoulders and the Acheron head. Dammit why can't we have a build-a-knight feature.
You could always get the Cerastus Knight Wing from FW plus the Atropos and have all of the parts to mix and match at your leisure.
Really? In the first Bulletin teaser, where they only showed the head and shoulders, I knew I wanted it as my first Knight. The fact the weapons are great, with rules to match, is gravy.
