Daemons and Realmgates
Frater,
I am looking to update my fledgling Daemonkin by adding the new GW Bloodthirster kit, but to make it look even cooler I want to model the base using the AoS realmgates as though the Greater Daemon is emerging through it.
My question is, what is the best/easiest material to use to fill in the empty void of the realmgate to make it look Stargate SG-1 ish. I am going to be using the longer set of legs from the BT kit (the jumping ones) so pretty much the whole model would be through the gate.
Thanks in advance.
https://bolterandchainsword.com/topic/315370-daemons-and-realmgates/
Well my idea would be some plasticcard to have something to close the gate and then use some water effect like Vallejo Still Water effect.
If you paint the plasticcard you could ad some waves to the water effect and you would have the Stargate look for your gate.
