Current plastic vehicles suitable for heresy era?
wilks
Hi guy,
Now that the plastic heresy game is coming out, I can finally make myself a heresy/ scouring force,
however one issue I have is while the infantry is sorted I would like to eventually add some vehicles.
What I would like to know is are the current plastic marine vehicles suitable for a heresy/scouring force or are they way more advanced for the time period? I am mainly referring to Land raiders, Predators and vindicators. I would just like to know if the Forgeworld variants are mainly for aesthetic value as I can get two plastic tanks for the price of one forge world one and the only real differences seem minor like side vents and rounded turret tops.
All help is appreciated,
Cheers guys.
For Space Marines, you're fine to use Whirlwinds, Vindicators, Land Raiders, and Rhinos in plastic. In 30k they're often just called the Mars pattern and are supposedly a little less common but easy to produce (thus why they become more common after the devastation of the heresy).
Predators are fine too, but remember that the Predator Annihilator TL Lascannon variant doesn't exist yet, and 30k Predator load-outs include a bunch of cool weapons that aren't in the regular 40k Predator kit. Executioner plasma cannon/Flamestorm cannon/Magna-Melta/Conversion Beamer can all be converted for cheaper than buying the FW conversion kits though.
Land Raider Crusaders and Redeemers do not exist either. Well, Mechanicum can get varied sponsons, which includes Flamestorm Cannons, but not SM. I think the best way going about this is not glueing the weapons and make them interchangeable for use in 30k and 40k.
Basically you can use all the chassis variants - they are mars pattern, just use the right weapons :)
Sadly ... the Macroblahblah Explorator in the red book has not the same options as the Mechanicum LR in betrayal, and is missing the flamestorm cannons - someone really should ask FW if the Mechanicum LR is really no longer valid :/
Thanks for all the help guys really appreciated. There are that I just thought I would check as  well. In the link Amayasu helpfully put up it says that the current marine style of dreadnought is also in use is this true? as I have never seen it portrayed as far as I know in any heresy novels I have read so far. I thought Only contempors were around at this time. and also just to check that the plastic current Landspeeder is also acceptable, again is it just another variant at the time?
Also if it helps I will more then likely be going with the Imperial fists legion.
Yep, box-Dreads (Castra-Ferrum pattern) do exist in 30k. Again, they have some different weapon load-outs from 40k. For example Assault Cannons in their 40k incarnation are in the experimental stage in 30k and the boxes can't mount them, but they can mount Volkite Culverin beam weaponry (awesome).
The reason you see Contemptors more often is because... uhm, they're cool, and if you're writing on the Heresy you tend to want to use the toys unique to the Heresy. I think that's the only reason.
Plastic Landspeeders can also be used, yes :) And, actually, attack bikes too now that I think on it. Again, different weapon load-outs. Land Speeders can take Graviton Rifles (NOT 40k Grav, they are different).
Can I use 40k rhinos for 30k I want to
Put alpha doors on them
You definitely can. In fact, you may notice the Legion Rhino door accessories don't even fit on Deimos pattern Rhinos anyway. 30k Mars pattern all the way yo
So actually, none of the 40k plastic-only flyers :P Only stuff made by FW in the air in 30k, unfortunately. Or fortunately? They look better, at least.
And who knows, if this plastic 30k thing takes off maybe we'll see plastic Storm Eagles... would sure be nice to not have to deal with that kit in resin ever again
Oh, it lost Flamestorm? Well, Nevermind. It got Irradiation Engines instead. Same thing :P Haven't looked at the Macroraid entry as of yet, mostly because my red book is still on order.
But my point still lands. You better learn to love Lascannons :D
