Where do you think the Lion will rank table top wise?
Emperor's Furor
We have quite a few Primarchs out now and there's certainly some beasts, but there's also some pretty "weak" Primarchs in terms of personal protection (of course they do make up for it in other areas, like army buffs) but I was wondering where you think the up coming Primarchs will rank amongst their brothers, specifically the Lion? For me the Lion has always kind of been middle of the ground, but recent encountered with the likes of Night Haunter have made me question whether he's actually a bit further up the pecking order.
What do you think?
High...the guy brawled with Russ for a day without getting punked
When he got down to business , he left Curze bleeding out on the ground. This is my opinion...cuz in his 1st fight with Curze, I think he underestimates his foe
When he plays cat and mouse with Curze on his ship...he's able to outmaneuver Curze (but his vox betrays him...kinda cliched but mainly cuz Curze has to survive because of plot)
To me, the Lion should be no weaker than Fulgrim and the Khan
The Lion doesn't need to be the best. He's just the best man for the job ;)
I honestly think he'll be pretty strong in combat due to some weird characteristics like Guilliman, but ultimately, he'll be a big buffer. Likely 4+ to seize the initiative, charge bonuses, and force manipulation.
I can see him having corax like knight stances.
Two handed great sword, +2 strength, rampage, murderous strike, armourbane
And a rule called "by any means necessary" that allows the lion to strike at initiative 10 in the first round of a challenge, but any attack targering him that turn gain +1 to hit.
The Lion should be a fantastic swordsman, possibly one of the strongest in terms of a duelist.
He should also bolster the army in a way to represent his Tactical planning.
If I was writing his rules...
Special Rules: Primarch, Bulky, Independent Character, Sire of the Dark Angels
WS8 BS5 STR7 T6 W6 I6 A5 LD10 2+
440points
-Lion's Blade: Str User, Ap2, Mastercrafted, Shred, Two Handed, Punishing Strike
Punishing Strike: May halve the number of attacks (rounding up). If so, Blade adds +3 to Str and becomes AP1
-Lion's Roar: Weapon counts as a Mastercrafted Plasma Pistol
-Armour of Caliban: The Armour of Caliban confers a 2+ save and a 4+ Invul. The Invul becomes 3+ when fighting in a challenge to reflect the Lion's incredible defensive combat skills when dueling against a singular opponent.
-Sire of the Dark Angels: Lion El Johnson may chose any Warlord trait from the Strategic traits found in the 40k rulebook. Also, D3 units in the army gain Infiltrate, Interceptor or Implacable Advance. In addition, an army containing Lion El Johnson may re roll attempts to seize the Initiative.
-Will of Caliban: Lion El Johnson may re roll failed Deny the Witch tests.
Something along those lines...
*Edit* Altered stats and weapon as per suggestions :-)
Definitely high WS and I, but not as high as the top tier speed of the Khan and Sanguinius. Russ was said to be stronger of the two, and the Lion, faster of the two.
I'd almost wager that the Lion gets a special rule to get d3 HoW hits with his weapon (I.E. Hits at I10) if he charges.
-Lion's Blade: Str User, Ap2, Mastercrafted, Shred, Punishing Strike
Punishing Strike: May half the number of attacks (rounding up). If so, Blade adds +3 to Str and becomes AP1
I think most of what you put in there was really good actually, but either make "Lion's Roar" a plasma blaster or make "Lion's Blade" 2-handed or a Specialist Weapon. Probably the latter.
I think the Lion should have both great buffs and great offensive capabilities, but while we joke about him killing his own guys, he should be the first primarch with serious force drawbacks to counteract his power. No allies, no orbital strikes, something that demonstrates his often-crippling devotion to secrecy.
He can kill his own Chaplains to generate Warp Charges for his Librarians msn-wink.gif
The warp charge pool cares not from whence the warp charges flow!!!
I hope that the 1st gains bonuses to plasma/volkite weaponry. Like reroll 1's of gets hot and reroll failed deflagrate wounds. But that's a bit on a tangent (pssst I called it "Weapons of a Bygone Age").
Hm, she should get the following rule:
No sense of humour - If the Lion is locked in close combat, each time the opponent laughs, Lion gets an automatic hit with S10 AP1 against his current close combat target.
:D
He's going to be tough to write I think. He's got to be level with Curze and Russ in combat and pretty much on par with Guilliman as a general. I think it could be very easy to make him too good. Not that I'd complain. On a side note, I'd like to see him with sword and shield. No primarch has done that yet.
As for the others... Khan seems the easiest to do. I think he'll be a glass cannon, insane initiative and attacks but not so tough (for a primarch). Magnus is probably going to be a devastating psyker but pretty average in combat (it's the only way to balance him).
Russ and Sanguinius will be the same problem as the Lion. Hard to balance, especially with the expectations of these two.
I have confidence in Alan Bligh though, he will find a way.
I think although his martial prowess needs to be shown either through WS or attacks or both, he's not as fast as the "fast" primarchs so he should be I6. He also needs something in the rules to represent his arrogance so needs a negative aspect in the vein of what wolf pack said where his opponent get plus one to hit because the lion thinks he can do the business straight away.
My gut feeling is that points wise he will be the most expensive primarch for the reasons stated above. He is a master duelist and strategist. I could see him get a rule that he can not join a unit due to his lone wolf nature.
I actually think they need an adjustment on the allies matrix to make them a little less co-operative with the other legions. Represent that "we got this" kinda mentality.
If he has an equal stat line to Curze but with more strategic based rule buffs , I'd be happy. Anything more is great.
I think the legion will get something to do with more archaic weaponry, for the Lion himself I think he'll end up being a "better" Rogal Dorn, mixing both tactical ability with close quarter prowess. I've not seen Guilliman's rules yet though, though I imagine he'll end up something like him.
I thought the Dark Angels were like addicted to plasma? Not choom? But that would be cool to have a choom-y Primarch
They just have a lot more of the esoteric weapons I think (Volkites, plasma) but because there isn't Volkites in 40k they just have lots of plasma.
*coughWeaponsofaBygoneAgecoughcough*
I personally made that rule to show that a lot of the 1st legion arsenal had handcrafted weapons from Mars that had much higher levels of craftsmanship and function than the other legions. Similiar to how mkII armor was handmade and sometimes preferred over the later marks.
There'll be probably some sort of rule that if the Lion doesn't beat anyone up in a challenge, you lose a victory point. Somewhat close to the Alpha Legion's Martial Hubris rule.
Knight stances:
Guarded Tower + 1 invulnerable, +1 toughness - 2 WS
Righteous Crusader + 1 A, Cleave (unsaved wounds cause an additional attack, cannot trigger itself)
Valourous Champion - (challenge only) +1 WS, prefered enemy (character) crippling strike (wounds suffered cause the model to lose 1 WS and Initiative for 1 round.
