Deekthegreat Posted November 4, 2015 Share Posted November 4, 2015 Having decided on the fist of dorn as my legion and with 2 boxes of betrayal at calth coming my way i am struggling with how to do a good imp fist scheme yellow seems so damn infuriating to paint can anyone tell me a good way to paint yellow? I was guessing averland sunset and yreil yellow and maybe badmoon yellow. Are those good colors to go with Link to comment https://bolterandchainsword.com/topic/315630-tips-for-imp-fists-paints/ Share on other sites More sharing options...
Slips Posted November 4, 2015 Share Posted November 4, 2015 Depends on the Type of Yellow. I just 'Wing It' for all of my stuff with a few colors always being around to get a roughly similar scheme the majority of the time. Prime: White or Black, this influences the Brightness of the Final Paintjob a bit. Yellow: Averland Sunset until primer is no longer visible Yriel Yellow or Flash Gits. This also determines how bright your yellow will be. Choice of Seraphim Sepia, Agrax Earthshade or Cassandora Yellow Washes. Sepia gives it a slightly worn look, Agrax makes it look dirty, Cassandora adds more Depth to the yellow (my personal go-to). Clean up with either the Color you used in Step 2 or Brighter. Glaze Lamenters Yellow if you want to boost the saturation of the yellow. I Personally Edge highlight with Dorn Yellow Sometimes. This can be done before or After the Lamenters Yellow. Another Easy-as-all-hell method is: Prime: WhiteYellow: Seraphim Sepia or Agrax Earthshade the Details. Cassandora Yellow if you want a more Orange Yellow. Otherwise, Lamenters Yellow Glaze. Lamenters Yellow Glaze until you get to a saturation you're happy with. Depending on if you want to Dirty it up a bit, light/thin all-over wash of Seraphim Sepia. This method is probably the easiest and is my go-to for batch painting marines...when I prime them white. Though it will take longer since you have to wait for Shades and Glazes to dry. Will Edit this Post late with Pictures of models I've painted in a particular method. Edit: heres a Crappy Phone pic. [Hidden] isn't working for some reason v_v Polux was: Prime Black Averland Sunset Flash Gitz Agrax Earthshade Flash Gitz cleanup Very Fine Agrax Earthshade Detailing. Sigismund: Prime White Averland Sunset Yriel Yellow Cassandora Yellow Dorn Yellow Plasma Contemptor: Prime Black Averland Sunset Yriel Yellow Seraphim Sepia Flash Gitz Dorn Yellow Kheres Contemptor: Prime Black Averland Yriel Yellow Heavy Cassandora Yellow Dorn Yellow Deredeo: Prime Black Averland Sunset Flash Gits Heavy Cassandora Yellow Dorn Yellow. Link to comment https://bolterandchainsword.com/topic/315630-tips-for-imp-fists-paints/#findComment-4215532 Share on other sites More sharing options...
Marshal Rohr Posted November 4, 2015 Share Posted November 4, 2015 White Primer, Averland Sunset, Cassandora Yellow Shade, Yriel Yellow Layer (3x 1:2 Yriel Yellow to water mixture), Flash Gitz Yellow (2x 1:2 Flash Gitx to water mixture), Hexos Palesun Zenithal Dry Brush, Praexeti White High Zenithal Dry Brush (only the very tops of the armor panels as if the light is directly above the model), Lamenters Yellow Wash (2x 1:1:1 Lamenters Yellow, Water, Lahmian Medium). Then you sponge weather with storm vermin fur, focusing on the knuckles, knee caps, front of the thighs and calves, the back should have light spattering with heavy spattering directly above the heel where natural human motion kicks up the most dirt. Rune Fang Steel should then be applied sparingly to the places that will most frequently have contact with the other portions of the armor, strike plate edges, knees, elbows, and helmets, these should be washed in a 1:1:1 mixture of Agrax Earthshade and Lamina Medium. Apply transfers using microsol and microset, and use a fine detail brush to chip yellow and white with a fine sponge weathering. Take a stilling brush and flick Blood for the Blood God onto the face of the model most likely hit by splatter from exploding blood rounds sparings. Use Typhus Corrosion around each rivet before picking them out in black or lead belcher, if metallic is used, touch up with Nuln oil at a 1:1 mixture for depth. I also use Corrosion of the lower rim of each mark 3 plate to represent accumulated grime. Black should be simple highlights of 1:1 Abaddon Black to Screaming Skull, and the a 1:2 Black to Skull for a light highlight, blended via a nuln oil wash. The use Runefang Steel to add shipping to the black rims. I prefer Warlock Broze, to Runelord Brass, to 1:1 Runelord Brass/Rundefang Steel for the rivets, washed with a 1:1 Agrax earth shade to blend the layers. Link to comment https://bolterandchainsword.com/topic/315630-tips-for-imp-fists-paints/#findComment-4215603 Share on other sites More sharing options...
God-Potato of Mankind Posted November 4, 2015 Share Posted November 4, 2015 If you're after ease of painting, I heartily recommend the Yellow Army Painter spray. I use them all for my legions - Green for Sallies, Ultramarine blue for Ultramarines etc. Quick spray of black & the colour = perfectly ready model for extra layers & washes. Link to comment https://bolterandchainsword.com/topic/315630-tips-for-imp-fists-paints/#findComment-4215662 Share on other sites More sharing options...
Marshal Rohr Posted November 4, 2015 Share Posted November 4, 2015 I should take a minute to point out my scheme is easily on mark 3, because I do a metallic underlayer, but requires a huge time investment for marks 2,4, and 5. Link to comment https://bolterandchainsword.com/topic/315630-tips-for-imp-fists-paints/#findComment-4215997 Share on other sites More sharing options...
Slips Posted November 4, 2015 Share Posted November 4, 2015 Yeah doing Mark III with colored overplates but metallic under suit makes it much easier to paint in quantity since you dont have to go over an entire model. Same with Cataphractii to an extent with the Legs. Link to comment https://bolterandchainsword.com/topic/315630-tips-for-imp-fists-paints/#findComment-4216000 Share on other sites More sharing options...
Marshal Rohr Posted November 4, 2015 Share Posted November 4, 2015 Here's an example of the more time intensive mark 4. Link to comment https://bolterandchainsword.com/topic/315630-tips-for-imp-fists-paints/#findComment-4216004 Share on other sites More sharing options...
augustmanifesto Posted November 4, 2015 Share Posted November 4, 2015 If you want to work with yellow, really the only way to do it is with a spray application. Airbrush is strongly preferred over canned yellow. For good results, this is what i do: -Prime white-airbrush Yriel Yellow (3-4 medium layers). (I used to start with a layer of Averland Sunset, but it actually didn't help the process so I stopped). -shade the recesses with Scorched Brown (it's called something else now)-highlight 1 with Flashgitz yellow-highlight 2 with mix of Flashgitz and white (I made my own mix before GW released a edge-highlight yellow, I think it's called Dorn Yellow or something, best to just go with that. Two things to know: (1) it really helps to paint the parts individually for good coverage without gunking up the model from certain angles, and then assemble once painted; (2), almost inevitably, a solid coat of yellow will result in some degree of lost detail you will have to make up with your shading. If this is too much for you, I would honestly just forgo a "true yellow" approach to your Imperial Fists and use Averland Sunset, shade with a brown or a brown wash, and highlight with Yriel and then Flashgitz. Either way, Imperial Fists painters have to have a bit of the geneseed within them and share in their obsession with fastidious detail and discipline, otherwise you'll never finish. But that's about the rub of it. Link to comment https://bolterandchainsword.com/topic/315630-tips-for-imp-fists-paints/#findComment-4216131 Share on other sites More sharing options...
lionofjudah Posted November 5, 2015 Share Posted November 5, 2015 I triple prime mine- black/grey/white (zenithal). Thin aveland base, reikland flesh wash, Vallejo bright yellow, vby/khaki, khaki extreme highlight, thinned black wash in crevices and then detail. Link to comment https://bolterandchainsword.com/topic/315630-tips-for-imp-fists-paints/#findComment-4216400 Share on other sites More sharing options...
