Terkael Posted November 11, 2015 Share Posted November 11, 2015 Hello B&C Forgeworld has put out some amazing models for HH Word Bearers in the past few years. The models tend to have intricate pictograph lining in their armor. I know that it wouldn't be too hard to simply paint the symbols on but I was wondering if anyone has attempted to recreate in inlaid nature of the symbols by carving? I'm not sure there are dremel heads small enough to achieve this effect but maybe a very fine wood burner with some sanding could do the job? Any comments welcome! Link to comment https://bolterandchainsword.com/topic/315926-making-colchesian-pictographs-etched-into-armor/ Share on other sites More sharing options...
Bryan Blaire Posted November 11, 2015 Share Posted November 11, 2015 What about a small plastic inscriber or a hobby knife blade? Those should do the trick to etch symbols into plastic. Link to comment https://bolterandchainsword.com/topic/315926-making-colchesian-pictographs-etched-into-armor/#findComment-4222364 Share on other sites More sharing options...
Lucien Eilam Posted November 11, 2015 Share Posted November 11, 2015 A small scriber is probably what you want. No Dremel tool is going to be small enough or accurate enough. It's a lot easier working on resin than plastic, but if you're slow and careful it is possible. Depending on the complexity of the pattern, a heated needle might be easier on plastic. Or even drilling out a section, filling it with putty and sculpting the symbols on that. Link to comment https://bolterandchainsword.com/topic/315926-making-colchesian-pictographs-etched-into-armor/#findComment-4222376 Share on other sites More sharing options...
Gurth Posted November 11, 2015 Share Posted November 11, 2015 I wouldn’t use a hot needle on plastic: it’ll melt the plastic (that’s what you intend it to do), but that means the plastic wells up to the sides and creates very soft and rounded edges — not to mention you’ll soon pull strings of plastic along your needle. A “cold” (room temperature) needle will work much better, IMHO, and if the surface is large enough a plastic scriber like this is even handier: http://ecx.images-amazon.com/images/I/31songU6CgL.jpg Link to comment https://bolterandchainsword.com/topic/315926-making-colchesian-pictographs-etched-into-armor/#findComment-4222385 Share on other sites More sharing options...
Apostle of the 30th Host Posted November 11, 2015 Share Posted November 11, 2015 A thin layer of green stuff might work. Then carve symbols in with a knife or something? Definitely for larger models anyway. Link to comment https://bolterandchainsword.com/topic/315926-making-colchesian-pictographs-etched-into-armor/#findComment-4222408 Share on other sites More sharing options...
ElectricPaladin Posted November 11, 2015 Share Posted November 11, 2015 I've got a tungsten needle point probe that I use to poke guide holes for pins that would probably work. Link to comment https://bolterandchainsword.com/topic/315926-making-colchesian-pictographs-etched-into-armor/#findComment-4222427 Share on other sites More sharing options...
Terkael Posted November 12, 2015 Author Share Posted November 12, 2015 Thanks for all the ideas folks, I am looking forward to trying some of them out on those new tacticals from Betrayal at Calth. Link to comment https://bolterandchainsword.com/topic/315926-making-colchesian-pictographs-etched-into-armor/#findComment-4223249 Share on other sites More sharing options...
SquigBait Posted November 12, 2015 Share Posted November 12, 2015 I would suggest taking a look at scrimshaw techniques and tools, especially when working with resin. Those techniques will transfer well to what you are wanting to dom Link to comment https://bolterandchainsword.com/topic/315926-making-colchesian-pictographs-etched-into-armor/#findComment-4223466 Share on other sites More sharing options...
wilks Posted November 13, 2015 Share Posted November 13, 2015 I believe the Word bearers transfers in the Battle of Calth box come with runes and pictographs on them, so no need to even inscribe them. Anyway hope that is of some help to you. Link to comment https://bolterandchainsword.com/topic/315926-making-colchesian-pictographs-etched-into-armor/#findComment-4224145 Share on other sites More sharing options...
