Astartes Anti-Air - Hunter AND Stalker
Psykic_scribe
As both the Hunter (Skyspear) and Stalker (Icarus Stormcannons) are provided with the Rhino chassis, I thought that it might be interesting to convert an additional Rhino. So here is a styrene card and rod mod, with photos showing the unpainted conversion parts. I nearly forgot the headlamp blanking plates (parts 21 and 37) but those were quickly fixed (after these pics).
And the other side:
Hidden Content
The side plates are mounted on the standard external doors, which in turn are magnetised. So I can turn it back into a slightly modified Rhino if more transport units are needed.
Did it save any money over buying two models? Probably not.
Was it interesting to attempt? Somewhat, although I have declined to add any rivets (it’s not that great a model). unsure.png
Hi Arthanor.
The styrene bits were of several different thicknesses, I didn't have the right styrene rod in stock, some of the parts are filed-down H-beams (a lot of H-beam for some very small parts) and EBay made quite a bit of money out of me on those materials. laugh.png
It also took a lot of time cutting and filing, so my conclusion is that it wasn't worth the effort. Good learning experience but I wouldn't recommend repeating it.
