Helias_Tancred Posted November 23, 2015 Share Posted November 23, 2015 Hey all. Does anyone own/use the new GW Artificer brush? If so what do you think? Can you get small details with it and is the brush material (forgot which animal it is) worth it? $20 is a lot but the company that makes the brush for GW sells the exact same brush with their name on it for $30, so ..... Thanks. edit: I believe its sable? Link to comment https://bolterandchainsword.com/topic/316376-gws-artificer-brush-is-it-worth-it/ Share on other sites More sharing options...
Adra'Melek Posted November 23, 2015 Share Posted November 23, 2015 Not a high class painter but I like it. I've used a few brushes recommended by others and I generally can't stand them. I actually prefer the GW over all the other ones I've tried. But I don't tend to look after them very well. The general consensus tends to be 'try several until you go ones you like'. Not that it's much help to you :) I think there have been other comments on it when it was first released. Perhaps a search here or in 'News and rumours' would turn it up. From memory it was a mixed response, some really liking it and some thinking it was a waste of money. Link to comment https://bolterandchainsword.com/topic/316376-gws-artificer-brush-is-it-worth-it/#findComment-4233161 Share on other sites More sharing options...
Helias_Tancred Posted November 23, 2015 Author Share Posted November 23, 2015 Thank you. I will do that :) Link to comment https://bolterandchainsword.com/topic/316376-gws-artificer-brush-is-it-worth-it/#findComment-4233195 Share on other sites More sharing options...
