3k Alpha Legion, assistance needed for a "end goal army".
So a friend of mine is jumping into 30k with the new box and he wanted a end goal army to build towards. This is what he has come up with.
The thing i see with this, is that most of his infantry wants to infiltrate, but that leaves the dreadnoughts quite back and alone. Mainly as they arent equipped with long range weapons.
HQ
Lynat
Exodus
Elite
10man headhunters, sgt. Artificer, powerfist and inferno p.
Contemtor Dread Talon
2x Kheres, extra armor
1x Plasma cannon, extra armor, heavy flamer
Apothecary attackment, 3 with artificer armor
20 tactical marines, sgt. artificer armor + meltabombs, powerfist
10 man tactical support, Caliveres, artificer armour, meltabombs
Heavy
Predator Squadron, 2x excecutioner cannons, 1x predator cannon, Armoured ceramite
Deimos Pattern Laser Destroyer, siege shield
Leviathan Dread, Armoured Ceramite, Storm cannon, Grav-flux
Apologies for the delay replying to this!
Exodus is cool, but a bit useless unfortunately. If his model is amazing when it's released, I'll probably grab him. But until then, leave him at home.
Headhunters are actually Fast Attack. They can take also a Dreadclaw as a DT, giving Dynat a good place to work from. Try this instead:
4 Headhunters: heavy bolter; + 1 Headhunter Prime (artificer armour; power fist & dagger; melta bombs), Anvillus Pattern Dreadclaw Drop Pod. 315
Cheaper by 35 points, the Prime has an extra attack, comes in 1st Turn and Dynat gains Preferred Enemy (Infantry). You will also have a free Elite slot, allowing you to turn 1 Kheres Contemptor into a Mortis for anti-air.
If you're going for 20-man Tactical Squads, you should at least give them a Vexilla and additional combat blades. May as well add power daggers to the Sergeants too.
If your going to mix roles on the Predators, give the odd-one-out Machine Spirit, so it can target something else.
Hope this helps!
