AlphariusOmegon108 Posted November 30, 2015 Share Posted November 30, 2015 Hey hey! I am looking into easily accesible products for me to strip old painted models, and maybe even remove super glue. Would ispropanol work? Does it soften plastics? Does it affect resins or metals in any way? If you have any experience with this material for miniatures, please let me know! have a good one, -Alex Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/ Share on other sites More sharing options...
Bartali Posted November 30, 2015 Share Posted November 30, 2015 By all accounts most alcohol based cleaners/thinners work well without effecting the plastic. Depends which one you can get the cheapest / most easily. I use Dettol, and it works well for me. I've found the key is to pour the contents into a seal-able container, dunk the minis in it and let them soak overnight. Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4239280 Share on other sites More sharing options...
Graymane Posted December 1, 2015 Share Posted December 1, 2015 Good choice. Isopropyl alcohol is what i use (Baught from Maplin electronics by the litre). Swear by it. Leave it for a few hours/24 hours pending how thick the paint is and then scrub with toothbrush. Works well on metal and plastic. Personally i have had no isses with resin either, but its worth testing on a small cut-off. Hope is helps! Cheers, Graymane Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4240601 Share on other sites More sharing options...
JGeils81 Posted December 1, 2015 Share Posted December 1, 2015 I've used it with mixed success. Depends on the type of paint/sealer used, and age.. Some worked within 12 hours, some it had no effect on. I've been using Purple Power now. Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4240695 Share on other sites More sharing options...
Kastor Krieg Posted December 1, 2015 Share Posted December 1, 2015 IPA is best when used in an ultrasound washer. Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4240745 Share on other sites More sharing options...
Acebaur Posted December 1, 2015 Share Posted December 1, 2015 Superclean is hands down the best product I've ever seen or used for stripping mini's. It easily strips paint, doesn't hurt the plastic and also dissolves glue. You can find it at any car care store http://www.supercleancanada.ca/images/superclean_cleaner_degreaser_group.png Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4240901 Share on other sites More sharing options...
AlphariusOmegon108 Posted December 2, 2015 Author Share Posted December 2, 2015 I've used it with mixed success. Depends on the type of paint/sealer used, and age.. Some worked within 12 hours, some it had no effect on. I've been using Purple Power now. Has it worked well on Gw and Vallejo paints? Especially when no varnish was used? Superclean is hands down the best product I've ever seen or used for stripping mini's. It easily strips paint, doesn't hurt the plastic and also dissolves glue. You can find it at any car care store http://www.supercleancanada.ca/images/superclean_cleaner_degreaser_group.png Thanks for the tip! I will have a look at that Good choice. Isopropyl alcohol is what i use (Baught from Maplin electronics by the litre). Swear by it. Leave it for a few hours/24 hours pending how thick the paint is and then scrub with toothbrush. Works well on metal and plastic. Personally i have had no isses with resin either, but its worth testing on a small cut-off. Hope is helps! Cheers, Graymane have you also got experience with if it dissolves glues? Like super glue and the gw plastic glue? Thanks so far for all the experiences people! Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4241114 Share on other sites More sharing options...
Bartali Posted December 2, 2015 Share Posted December 2, 2015 Any 'Paint stripper' won't dissolve polystyrene cement (GW Plastic Glue), it works by melting the plastic together. Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4241292 Share on other sites More sharing options...
Acebaur Posted December 2, 2015 Share Posted December 2, 2015 Any 'Paint stripper' won't dissolve polystyrene cement (GW Plastic Glue), it works by melting the plastic together. No, but anything that is cyanoacrylate will, which is what most people use. Plastic cement has a much longer dry time, and so is less often used by most modelers. Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4241642 Share on other sites More sharing options...
Honda Posted December 6, 2015 Share Posted December 6, 2015 Plastic cement has a much longer dry time, and so is less often used by most modelers. Which seems to be the default glue whenever I get a reclamation project from ebay. :\ Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4245194 Share on other sites More sharing options...
Graymane Posted December 9, 2015 Share Posted December 9, 2015 have you also got experience with if it dissolves glues? Like super glue and the gw plastic glue? Plastic cement it has no effect on. Most superglue i find it renders very brittle, so even a slight pressure pops the parts free. Others, however, remain solid. Sorry to be a bit vague, but thats just on the basis of my experience. :) Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4247798 Share on other sites More sharing options...
Warsmith Uveron Posted December 10, 2015 Share Posted December 10, 2015 Most Plastic Cement bonds will not break down with paint stripper as Plastic Cement melts the plastic and forms a soild bond. Now I say most cases, because I find that quite often the bond will not be perfect and the stress of cleaning on the joints will cause them to break, but its just as likely to break along any line of weakness. Just as a FYI, I use Mean Green Cleaner, which I soak the model in for 2 to 4 months.. and then it goes in a Ultra-sonic Cleaner (A Cheep one I picked up from Amazon), and it gets turned on every few days.. within a week 90% of parts are clean without much work on my part. A few parts need some scraping others with a thick cover of paint need a brush with a old tooth brush before another week in the Ultra-Sonic Cleaner. Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4248595 Share on other sites More sharing options...
Acebaur Posted December 10, 2015 Share Posted December 10, 2015 2-4 months?!? Superclean will strip most anything within a day. Maybe you should check that out instead. Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4248845 Share on other sites More sharing options...
Warsmith Uveron Posted December 10, 2015 Share Posted December 10, 2015 2-4 months?!? Superclean will strip most anything within a day. Maybe you should check that out instead. Its mostly because I am lazy... and I have been stripping and breaking down a whole IG infantry army and a pile of Tanks and two medium size chaos Marine armys... I have a whole cooler full of models and paint stripper. I have stripped a model with a few hours with some elbow grease and the ultrasonic cleaner, leaving it on the extended soak means that some of the IG I painted in 1997-2003 3 or 4 times without stripping just require a quick rinse under the tap to get it back to bare plastic (even the primer will be lifted) Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4248897 Share on other sites More sharing options...
Bartali Posted December 11, 2015 Share Posted December 11, 2015 Any 'Paint stripper' won't dissolve polystyrene cement (GW Plastic Glue), it works by melting the plastic together. No, but anything that is cyanoacrylate will, which is what most people use. Plastic cement has a much longer dry time, and so is less often used by most modelers. I don't know if that's quite right. I imagine most people putting plastic GW stuff together use Poly cement - it's what GW sells to customers for gluing plastic kits and it's easy to use I quick check on some of the military modelling forums I frequent show they mostly use poly cement, probably 60/40 vs Cyanoacrylate Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4249299 Share on other sites More sharing options...
Warsmith Uveron Posted December 11, 2015 Share Posted December 11, 2015 Yes all types of Poly Cement melt plastic, so it all will have the same issues as I and Bartali Described. Check out this LINK for more information on this type of thing. Link to comment https://bolterandchainsword.com/topic/316592-isopropanol-as-paint-and-glue-stripper/#findComment-4249590 Share on other sites More sharing options...
