broken drop pod door
Stezza
Magnets are the only real solution with disassembling the pod. I'd recommend replacing both pins and a third on at the top to hold it closed. I'd recommend 2mm or 3mm diameter with 3mm depth, as it's the depth that give magnets their strength.
Cheers,
Jono
