Arctic Circle During Unification/Heresy Eras
Lunar Centurion
What was the northern part of Terra like during Unification and the Heresy? I want to base my Imperialis Militia off of a Scandinavian force (Not vikings, just cold/icy Cadians), but because I love the fluff, I'm wondering what to call them, and what to do for terrain. I was kind of thinking clear-ish terrain with some ZM, but I'm not really sure. Thanks in advance!
Bear in mind that by the year 40,000 (and probably a lot sooner) there was no water left on the surface of earth, temperatures had risen, and cities covered most of the planet.
There would still be people of scandinavian heritage in existence however the specific countries as you know them would be long gone, replaced with a region, for which you can make up your own 40k sounding name (Skadiks, Norskers, Daens etc.).
Okay thanks. Btw, didn't the south pole still have ice? That's where the Inquisition have their fortress, and it's under ice.
I havn't read that piece of fluff, but it is possible that ice may persist at the south pole, and at extreme heights, but with the seas gone, there definitely wasn't an ice sheet in the north.
Real world rules apply, so more northern latitudes would still be colder than southern, etc. I dont think BL writers bother with wobble and orbital precession and stuff like that.
As I understand it, if a large part of the water had been physically destroyed or burnt off into space, and then the temperature had fallen after this event, then it would in theory be possible to have dry oceans and yet still have ice at the poles.
Equally, it may be that not all the writers have read all the other writer's stuff.
Water covers 75% of the world's surface currently. The loss of that much water would render the planet uninhabitable. How was food being produced to feed the billions living on Earth during the Unification wars? How was breathable air being produced?
Because it is warhammer
Science is possibly the answer to this. The Mechanicum may have built an atmosphere-creator machine or something.
Lunar Centurion, why not base it in the South Pole then, given there's definitely still ice there?
So maybe do a proto-Inquisition type thing? B/c iirc the Inquistion was based there, so they could be kinda like them.
I know the inquisition fortress is talked about in the 'inquisition war' book series, but most of the fluff in that has fallen by the wayside over the years (it's good for a look at the VERY early ideas of modern 40k but its mostly irrelevant now) and not sure if its mentioned anywhere else.
At the beginning of Scars there's a lad from Terra and he is mentioned as being from the Scandinavian region, but I cant remember off hand what it says about the area (I only have it on audiobook so its not easy to reference it).
I'm sure in Nemisis there is an assassin kept frozen on the South Pole and I got the impression it was still all frozen.
In the Nemesis audio book the only assassin kept under ice is the Eversor (The Guarantine) and he is not found on earth but in a base of operations on another planet that I cannot recall, and he is in stasis not just frozen.
It depends on what you read. There have been a few references to islands on Terra in various novels/stories and that implies bodies of water if not necessarily oceans.
There has also been a few mentions of the Emperor trying to rehabilitate Terra's ecosystem so that's how I've always rationalised the inconsistencies.
So, with that in mind, the Scandinavian theme is fine. Just make them late crusade after the Emperor starts cleaning the place up.
Ahhh I thought it was Terra and the Antarctic. Probably got rushed that book a bit and used my mind to fill the gaps....
If they can smooth such a large amount of Ullanor down to a nice shiny finish, fill in caves/valleys and wipe entire mountains of the face of the planet, (likely using DAoT tech) there probably is some kind of stable ecosystem on Terra.
Perhaps the oceans are cover entirely different parts of the globe and Terra could look entirely different in 28,000 years.
Not to mention there will be an ice age between now and then. I think you would be perfectly okay to use the Arctic circle in your fluff.
I know the Venenum (whatever the actual correct spelling is) assassins are based in a tropical forest upon terra near the equator, for rain forests there has to be clean water so there must still be a fair amount upon Terra.
I suspect it boils down to the authors not having Neill Degrasse Tyson leaning over their shoulders and smacking them with a rolled up paper every time they wrote something that would make an environmental scientist do a spit take.
