Rasclomalum Posted December 5, 2015 Share Posted December 5, 2015 The Orange: Primer: White spray (whatever the GW stuff is called). Primer Shade: Nuln oil. Base: Jokaero orange. Base shade: Seraphim Sepia. Layer: Troll Slayer Orange. Highlight: Fire Dragon Bright The White Primer: White primer Primer shade: Nuln oil Base: Ceramic White Layer: White Scar QUESTION: Any recommendations to make the white stand out better? The Metal Primer: White primer First base: Abaddon Black Second base: Leadbelcher Shade: Nuln oil Layer: Ironbreaker Link to comment https://bolterandchainsword.com/topic/316791-would-this-recipe-work-for-my-orange-and-white-space-wolves/ Share on other sites More sharing options...
Razblood Posted December 6, 2015 Share Posted December 6, 2015 Use Ulthuan or Celestra Grey as the base for the white, it'll give you a more natural gradient. Also using Nuln Oil as a primer shade on the orange is a bit redundant as you'll be covering the whole area with Jokaero Orange anyway. Link to comment https://bolterandchainsword.com/topic/316791-would-this-recipe-work-for-my-orange-and-white-space-wolves/#findComment-4245205 Share on other sites More sharing options...
appiah4 Posted December 7, 2015 Share Posted December 7, 2015 It really doesn't seem very practical to nuln oil shade a white primer and then try to build a basecoat on it using foundation paints - they are completely opaque and will not benefit from the preshading at all. And if you try to use layer paints straight away, those will likely lead to poor coverage over white with transparent colors like white and orange and cause much frustration. I'd suggest just going for a darker shade of opaque basecoat for each, then shade that and layer with a midtone and then up to a highlight. It's a much more conventional way of painting, but there's a reason why conventions hold. I have a feeling orange or white over a nuln oiled white primer just won't look the way you think it will. But if it works for you, do let me know as well Link to comment https://bolterandchainsword.com/topic/316791-would-this-recipe-work-for-my-orange-and-white-space-wolves/#findComment-4245518 Share on other sites More sharing options...
Rasclomalum Posted December 7, 2015 Author Share Posted December 7, 2015 Thank you. I though the preshading would work well, but it seems I've been talked out of it. :-) Link to comment https://bolterandchainsword.com/topic/316791-would-this-recipe-work-for-my-orange-and-white-space-wolves/#findComment-4245789 Share on other sites More sharing options...
K0rtmer Posted December 8, 2015 Share Posted December 8, 2015 Well, I don't mean to overcomplicate things, but decent pre-shading can make a difference – depending on how strong you're planning to build up your base coat. But I don't think Nuln Oil over a white primer will cut it. A better, also easier pre-shading technique is to prime everything black, and then use white primer from only the top (similar to as you'd do zenithal highlighting). Again, it's embarrassingly simple and will define different levels of color saturation for your base coat, provided you don't build it up too thick. But you don't want that anyway. I can't comment on the strategy you proposed above. I'd advise to use an old model and just give it a shot. Keep us posted. Link to comment https://bolterandchainsword.com/topic/316791-would-this-recipe-work-for-my-orange-and-white-space-wolves/#findComment-4246442 Share on other sites More sharing options...
