Best choice for templar bretheren legs and arms
Brother Achiles
They're clearly designed for the mk3 despoiler squad, and it's silly that they don't just include the extra bits.  You'll be left with lots of spare parts that you can sprinkle into your other squads.  If you have old 40K marine parts lying around and you don't mind dirtying your pure 30K force with a bit of 40K plastic you can get some value out of them.  Even if you're a resin purist there's lots of extra bits.  My IF force is designed specifically to put to use my old 40K stuff that I wouldn't otherwise bother with, and I got as much out of the kit as possible.  I ended up with 7 Templars and enough bits to add bling to a command squad.
While the upgrade kit + basic marines makes the templars/warder kits expensive, they are cheap compared to other upgrade kits :
A IF upgrade bundle,mat £44, includes heads, chests and pads fo 10 marines.
For the same price you can get two templar kits which includes just as many heads and chests, but also includes 10 extra pads, shields and swords...
More expensive than palatine blades or reavers, yeah, but still a great item nonetheless... And at £34 + £22 for despoilers + templar kit, they're still less expensive than suzerains and you end up with a fair bunch of extra bits!
Ok great stuff. will use what I have then. Have heard mixed reports about Templar bretheren, mostly that it would be better to take some terminators with vigil pattern storm shields instead. Thoughts on this ?
I like both units , Templar are a lot of fun with sigismund because they  get the +1 initative and hit at str 5 ap 3 on the charge  ( you will need a land raider )
That being said
Sigismund + Terminators is also solid Vigil Shields and Thunder Hammers are great but youll need a spartan  for this unit
Terminators tend to be better at helping Sigismund hunt the enemy warlord which is what you want him  to be doing , though I find Templar brethren are fine WITHOUT sigismund at just destroying   groups of 3+ save marines
I would say build both units cause both are very fun
Sigi+Termies wouldnt fit in a Land Raider because it only has 10 slots unless you used a 4 man TDA command Squad. But at that point your paying for a fearless bubble from the standard that the squad doesnt benefit from due to Sigismunds Fearless.
