INVICTARUS SUZERAINs...
shandwen
So about a month qgo I ordered a squad of these guys. Order arrives and I find a dreadnaught blastmaster arm... call FW and get them to send me the proper order (they did let me keep the worthless dread arm).
I start building them (after washing them in a warm soapy basin to clean the pqrts and all. No warping or issues with the kit. But it takes forever to get the pieces to stick. Had to go out and get gel superglue instead of the normal stuff. Still takes a half a minute a piece to have the glue hold (even with scoring the smooth parts first). Qfter a good two hour have nothing but the shoulder pads left.. then I realized that with having the backpacks already on the fancy shoulders wouldn't fit (not that they fit well anyways...). So pong story short if I buy anymore Fw stuff I think I'll just pay someone else to build it for me and I'm waiting on some smaller shoulder pads to arrive to put on these guys (easier than breaking apart the models to fit the proper ones on).
But perhaps ill start a wip thread on my XIII Legion.
https://bolterandchainsword.com/topic/316986-invictarus-suzerains/
If you ever try to build any Forgeworld stuff again, try washing the pieces in warm soapy water first. The resin release agent on the pieces can get pretty bad sometimes. It usually just impedes painting but I've had it bad enough where pieces won't stick together as well.
If you did wash it first, that sounds like a really bad experience. I'm sorry you've had such bad luck with forge world so far. I hope you have better future experiences. I look forward to seeing a wip log!
Their quality control is pretty bad frankly, but their customer service is second to none. I've had so many damaged parts/missing models over the years but every time they've been fixed without question and I ended up needlessly stressing for no reason. Hopefully you have a better experience in the future because most kits won't be that problematic. If they are unusable, just email FW again (I prefer ringing as you get a faster response) and they will replace them
I will admit this particular kit was quite hard to put together as far as infantry goes.
Super glue is the only way to get the pieces to stick, never use plastic glue for Resin.
And yes, the shoulder pads have to go on first, with the backpack being stuck on last.
I'd suggest you simply use some more basic shoulder pads, mk III for example, as ripping the packs off could be damaging to the models depending on how well glued they are.
Don't let this experience put you off, the first time working with FW resin has the potential to go wrong. Other kits are more straightforward, but some can be even more difficult!
*Edit* i see you're already getting smaller shoulder pads, I also think this is the best thing to do.
I see you washed it beforehand, but if you were trying to use "normal" glue (what is that, plastic glue or pva?) then you were always in for a bad experience. You should have a look at this Working With Resin video - very helpful.
https://m.youtube.com/watch?v=4UNAjik9S80&feature=youtu.be
Don't give up on FW! As Marshall Loss said, their customer service is second-to-none so they'll always help out where you need it! :)
