ChazSexington Posted December 11, 2015 Share Posted December 11, 2015 I've decided to rebase my Alpha Legionnaires on 32mm, but changing the bases to a jungle theme rather than the basic GW ones. I found these, but they're 25mm, and I'm not that keen on adding the extra lip around it, as I'm not a fan of lipped bases. I've also found this, but I'd rather have the previous ones (or something similar) in 32mm. Anyone know of any? Link to comment https://bolterandchainsword.com/topic/317028-jungle-bases/ Share on other sites More sharing options...
Lucien Eilam Posted December 11, 2015 Share Posted December 11, 2015 The Citadel Death World Basing Kit has bits very similar to the first style you've linked there, but you can add them to any base. Link to comment https://bolterandchainsword.com/topic/317028-jungle-bases/#findComment-4249427 Share on other sites More sharing options...
Amayasu Posted December 11, 2015 Share Posted December 11, 2015 Kromlech might be worth a look - http://bitsofwar.com/50-resin-bases-new Link to comment https://bolterandchainsword.com/topic/317028-jungle-bases/#findComment-4249445 Share on other sites More sharing options...
ChazSexington Posted December 11, 2015 Author Share Posted December 11, 2015 The Citadel Death World Basing Kit has bits very similar to the first style you've linked there, but you can add them to any base. Hadn't even thought of that! Cheers! Kromlech might be worth a look - http://bitsofwar.com/50-resin-bases-new Those are pretty damn good too! Cheers! Link to comment https://bolterandchainsword.com/topic/317028-jungle-bases/#findComment-4249480 Share on other sites More sharing options...
