Did you go from 25mm to 32mm bases?
Prot
I think it was a move designed to make it harder to sell second hand models.
Given that the main reason the legs stick out from the base is the near universal squat stance they come with, it would have been better to make the marines stand more upright. That would have given them a little bit of extra height, a much better pose, and not taken up so much room on the table or wherever they're stored.
If you want to make the marines obviously larger than guard then the other thing for GW to do is make the guard smaller, go back to the size they were such as the old metal Cadians. Better to change the size of the guard than the much more numerous marines. The other problem is that the larger base will result in larger marines due to scale creep, again making the older models less usable.
Why would it make re-selling harder? Base size isn't exactly an obstacle; they are easily replaced, as proven by people who are re-basing their existing armies. I don't see it as anything other than an aesthetic choice, and one which I wholeheartedly agree with.
I've not consciously done this - and knowing that I have far too many things on 25mm bases, I think it would be odd to change! That said, I may switch smaller armies, or indeed - new armies, to that format. I just can't imagine rebasing my Death Guard legion, especially with the number of resin bases I have spread out among them too.
Yes, that is what I'm doing, my Csms and kdk are going to be on 25mm, with my bac I'm going to make into a vanilla marine army, I'm going to keep it small, the power armor guys being sternguard, allied with my grey knights.
I've kept my army pure 25mm and plan on putting any new 32mm kits on 25mm too. The only exception is the HQ but it's the Centurion/Praetor who doesn't even fit on a 25mm and I have no idea how people put their FW Praetor on a 25mm before the 32mm bases came out. To me, there's too many reasons to not switch to 32mm.
- I prefer the look of 25mm.
- My army isn't powerful, so I need the smaller footprint to hide behind buildings against armies like Tau.
- My expensive foam cases fit 25mm, not 32mm.
- My army is already all on 25mm.
- Most of my models have upright legs, meaning the 32mm base looks very empty and too large, like Terminators on a 40mm.
The only reason I can see to switch to 32mm is more assault benefits and more room for basing decoration, both very good reasons, but not enough for me to go through the effort of re-basing and putting up with the uglier base size.
  • 2 weeks later...
So I've just started doing marines in the post 32mm world.
Which means thus far I've put all my PA on 32's.
I finally have 2 squads scouts and I'm trying to decide from an aesthetic and practical/gaming POV if I go with 25 or 32.
At the moment I'm leaning towards 25 because they are smaller than regular SM and so I can squeeze them into places easier with out wobbly model.
I seem to have come late to this party what the hecks going on? Do I have to rebase all my Astra Militarum? I will happily use whatever base comes with the models personally and if that means old sets come with 25 and new ones with 32 I'll switch over to the 32s just to stay standard but where is this coming from and is it something I have to look at doing?
The newer Space Marine PA kits come with 32 mm. This was done purely for aesthetic reasons (apparently).
So far there are no other armies being released on 32 mm and no, you are under no obligation to rebase your collection.
Thank heavens. I hadn't heard about this though. Guess I shouldn't be surprised my group is very small and close knit :) Appreciate the heads up though.
I'm one of the people that are in limbo on this issue.
I have based my new devastators and most of my characters on 32mm because they look much steadier that way, but all the basic troopers I have left to build will still go on 25mm bases (which they were provided with anyway). My general observation is that people that are leaning toward the artistic side of the hobby tend to go with the larger bases, as they provide more opportunities for expression, while the "gamers" tend to ignore the issue. I haven't so far run into someone who decided to rebase their whole army for reasons other than aesthetics.
My Sisters come on 25mm bases and don't look out of place on them, so I don't need to change them. However, I might stick my Seraphim on 32mm, as I've heard that they tend to be rather unstable. If I can get away with leaving them on 25 mm, then they'll stay that way too.
However, when I get around to (re)starting Marines, I might go straight to 32mm.
I went all in, I bought a 100-pack of 32mm bases and isn't looking back!
The larger bases make them feel properly large when compared to a mortal!
http://imageshack.com/a/img908/492/r1xH3l.jpg
[Edit]: Just using them for my astartes, forgot to say. :P
Yet........
I've decided to use the 32mm only for 2 wound characters (3 wounds gets a 40mm) and the standard bearer since he won't stand up otherwise. The rest remain on 25mm. I'm not going to buy new battle foam trays to accommodate new bases.
A few other armies are in the process of changing already; Necron Warriors and Immortals have already been repacked with 32mm and I'd expect the rest of the Necron infantry kits to follow suit eventually. The CSM squad kit has been repacked and it's inevitable that the rest of that range will change as well. The Bloodletters and Plaguebearers in the two new "Start Collecting" boxes come with 32mm which suggests that the other lesser daemons will follow, and Tau Stealth Suits were reboxed with 32mm as well, which to me indicates that other larger infantry models in ranges of smaller infantry (ie Genestealers) might well get the same treatment. Orks seem like they are big enough to warrant it as well so I wouldn't be surprised to see them change in the future (indeed, it looks like their AoS equivalents are on 32mm in the Start Collecting! Greenskinz box)
