Penitent Engines
Yes I quite agree... when I see that threads about the struggles people have assembling their exorcists... I smile inwardly and wonder when they will try to assemble a PE.
The joints of the PE give a deceptive impression that assembly will be easy.
I have even found that pinning isn't as effective on the PE as it is on other models.
I still have to fix one of my PE that broke the pin in the ankles.
Congrats dude and welcome to team penitent! You can tell who else is in the team by the scars on our hands! laugh.png
I'm with you there mate. In fact, after my first failed attempt to pin one of mine, I just settled for sticking a small amount of greenstuff into the joins and blobbing some gel superglue on top of it. Six months later and they haven't broken apart yet! *Crosses fingers.* cool.png
Ahaha! Good old Saint Loctite - glueing metal mini's and hands together for generations! B)
Seriously though, Loctite Gel is the business! You have to hold the pieces together for a little while (which is why I also use a tiny bit of green stuff, to keep the parts in place while it dries) but when it's set, it's harder than dried Weetabix! :lol:
Oh, definitely Loctite all the way! I went through two bottles of it, half a pot of liquid green stuff, and more pins than you can shake a porcupine at assembling the things! But they turned out beautifully and are being painted as we speak!
I must truly be a glutton for punishment as I had just previously assembled two Exorcists. I've had the models for nigh on ten years and though my Sisters are battle hardened indeed, I only just found the courage to add more Heavy Support.
I didn't have THAT much trouble with my penitent engine or my exorcist (but I'm getting a second of each so we'll see...). What I really had trouble with was the turret on my immolator. I put that thing together and took it apart three times over several hours, and it still looks meh. That was the most frustrating experience I've had. Granted, I wasn't too worried by the gaps between my exorcist organ pipes.
