Strata Posted December 18, 2015 Share Posted December 18, 2015 So im at alittle bit of a loss at the moment on what i should do with my tactical squads out of BaC. Up untill release i have been working on Iron Warriors, using a mix of mk2/mk3 and Chaos parts. So with this thought, the stock mk4 dont exactly match up to the image i have going with my iron warriors. Seeing as i currently have 60 sitting on my desk waiting to be built, Does any one have an toughts of suggestions on how to correct this? Link to comment https://bolterandchainsword.com/topic/317279-ideas-on-how-to-chaos-up-the-bac-mk4-armor/ Share on other sites More sharing options...
Grotsmasha Posted December 18, 2015 Share Posted December 18, 2015 Being plastic, it does make kit-bashing and converting much easier. I'm going to assume that you,like most SM players, have a large bitz box. Swap out some torsos and shoulder guards, cut horns from spare helms and add them to the mkIV's. *IF* you've exhausted your bitz box, my only suggestion would be to buy more bitz, or split the mkIV's up into your previously completed squads so that they blend, rather than standing out a as seperate unit. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/317279-ideas-on-how-to-chaos-up-the-bac-mk4-armor/#findComment-4255481 Share on other sites More sharing options...
SW1 Posted December 20, 2015 Share Posted December 20, 2015 The pads can be converted to look like earlier marks with the addition of a plasticard edging/trim? I'm in the same boat as you. Currently weighing up the models to make them more wolf like. Link to comment https://bolterandchainsword.com/topic/317279-ideas-on-how-to-chaos-up-the-bac-mk4-armor/#findComment-4256947 Share on other sites More sharing options...
jlmb_123 Posted December 21, 2015 Share Posted December 21, 2015 You could buy some Chaos shoulder pads and spread them around, they're dirt cheap for a ton on eBay. Same goes for heads. Link to comment https://bolterandchainsword.com/topic/317279-ideas-on-how-to-chaos-up-the-bac-mk4-armor/#findComment-4257632 Share on other sites More sharing options...
