Cataphractii with fixed pads or Indomitus pads?
I have a magnetized set of 5 Cataphractii. I'd like the weapons to be interchangeable, but I only have 5 sets of pads. I can do two of the following - either use Indomitus pads or glue the Cataphractii pads directly to the torso and just exchange the arms. Since I'm not really too much of a fan of the Cataphractii style pads, I'm on the fence here. Help? :P
Here's a bluetac mockup of more or less how the Indomitus pads look on a Cata, I think it's quite cool.
http://i.imgur.com/aNqEKEQ.jpg
I went for fixed pads, and it worked just fine,
http://www.bolterandchainsword.com/topic/317799-365-days-of-hobbyhopefully/?p=4267364
Cheers,
Jono
Ha, that'd save me from robbing my bitz box and doing a LOT of painting msn-wink.gif
What was your poitn of contact for the pads? Bottom or top layer inner edge?
Cheers,
Jono
I glued the two parts of the pad together, there's a way to do it so that they are level, you just need to trim the little studs off the inside. I'll put up a pic later this afternoon.
Cheers,
Jono
OK, will look, thanks. In the meantime, unable to make my mind and without resources for a permanent solution either way, I've bluetacked the Cata pads to the Cata termies and called it a day :v
http://i.imgur.com/u3zfDHz.png
Those Indomnitus pads on cataphracts look pretty good actually, i may steal that idea.. biggrin.png
I was thinking of using the spare Cataphractii claws on a squad of 40k Assault Terminators so it's good to know that the indomitus pads fit :)
"Fit" is saying too much, but the do go onto these arms. Worst case, you can switch shoulders to Indomitus.
Well, I was hoping to simply add Indomitus shoulderpads straight on to the Cataphractii claw arms. I presume with a bit of trimming of the shoulder it should be easy enough?
Yeah, you can achieve more or less the above, the left one sits high on a ball of blutack. Generally they "fit", as in go onto the arm. In some cases, the "fitting" is more awkward than in others and you'd have to tilt them closer to the torso, for example.
