Death Guard 2k Infantry
Using the reaping ROW. C&C please. Is it better for a 10 man HWS or a 5 man?
+ HQ +
Legion Centurion [scout Armour]
Consul [Vigilator]
Legion Praetor [Artificer Armour, Iron Halo, Paragon Blade]
Master of the Legion [The Reaping]
+ Troops +
Legion Heavy Support Squad [Autocannons, 9x Legion Space Marines]
Legion Sergeant [Rad Grenades]
Legion Tactical Squad [19x Legion Tactical Space Marines]
Legion Tactical Sergeant [Artificer Armour, Power Fist, Rad Grenades]
Legion Tactical Squad [Legion Rhino Armoured Carrier, 9x Legion Tactical Space Marines]
Legion Tactical Sergeant [Artificer Armour, Power Fist]
Legion Veteran Tactical Squad [Legion Rhino Armoured Carrier, 9x Legion Veteran Space Marines, Missile Launcher and Suspensor Web, Volkite Charger]
Legion Veteran Sergeant [Artificer Armour, Power Fist, Rad Grenades]
+ Elites +
Apothecarion Detachment
Legion Apothecary [Artificer Armour, Augury Scanner, Rad Grenades]
Contemptor-Mortis Dreadnought [Two Kheres Pattern Assault Cannons]
+ Heavy Support +
Legion Spartan Assault Tank [Armoured Ceramite, Auxiliary Drive, Flare Shield]
+ Legion +
Legion Astartes [XIV: Death Guard]
https://bolterandchainsword.com/topic/317858-death-guard-2k-infantry/
Your Apothecaries don't need rad grenades if they're joining a unit with them. You probably don't need them on your autocannon squad either.
Whats the veteran tactic? With the points saved on dropping rad grenades you can swap out the charger for a heavy weapon with a web.
The veterans would have either sniper or outflank. I did what you suggested and im at 1995. I would put the vigilator likely with the autocannons if the terrain has a nice piece of ruins that gives me a good view of the field so I can infiltrate into it.
Vigilators can't infiltrate a unit anymore thanks to the new BRB errata.
I recommend heavy bolters for the vets if you're taking sniper. They can fire on the move and shoot out of the top of the rhino. For outflank two MLs for side and rear armor shots are good too.
The missiles can yes, at half range as assault 1.
Section Leader Mortug has the "Master of Ambush" warlord trait that allows you to select up to three non-vehicle units and grant them infiltrate. He too has infiltrate himself.
So long as you pick the unit inside the DT they can infiltrate with it.
Hmn he doesn't have master of the legion? That's rough. He's the only way I know that has guaranteed infiltrate thanks to his trait. Otherwise it's just rolling on the table. Which master of the legion allows you to roll twice and pick from the results so the chances are better.
