OrangeBob Posted January 6, 2016 Share Posted January 6, 2016 This seems like an odd question but I can't wrap my head around the concept. I've seen many WIP articles online that show that the bases have been completed before the model is attached to said base. I can't seem to figure out how the model is attached to a finished base, what with all the sand and mock and other crap that we use to base our minis. Is it so simple that people just glue models on top of all of that basing material and texture? What am I missing here? It seems like the bond between the resin/plastic of the model and basing material (often painted) would be iffy at best. I sure hope this is something simple that I just haven't figured out, because texturing the base without the model attached would be so much easier. Thanks, Orangebob Link to comment https://bolterandchainsword.com/topic/317896-glueing-models-to-finished-bases/ Share on other sites More sharing options...
Grotsmasha Posted January 6, 2016 Share Posted January 6, 2016 At a guess, I'd assume most would be pinning the feet through the base, but a good enough glue, especially with plastic models would be fine. Link to comment https://bolterandchainsword.com/topic/317896-glueing-models-to-finished-bases/#findComment-4269724 Share on other sites More sharing options...
Lucien Eilam Posted January 6, 2016 Share Posted January 6, 2016 Pin through one foot. And depending on the type of base, gluing at least some of the basing material down with the model in place, so the feet will be slightly depressed relative to the surface. Otherwise he'll look like he's floating. Link to comment https://bolterandchainsword.com/topic/317896-glueing-models-to-finished-bases/#findComment-4269792 Share on other sites More sharing options...
anselneo Posted January 6, 2016 Share Posted January 6, 2016 Depends really on the model and the base, I usually just superglue them to the base, i find that the thick super works fine. If you use a sandy base, it just settles in to all the sand. For more tricker bases, i usually stick a pin through a foot. You should be able to see some via the link in my signature Link to comment https://bolterandchainsword.com/topic/317896-glueing-models-to-finished-bases/#findComment-4269801 Share on other sites More sharing options...
JGeils81 Posted January 6, 2016 Share Posted January 6, 2016 I've been pinning both feet through the base, unless only one foot is touching(walking/running etc. Link to comment https://bolterandchainsword.com/topic/317896-glueing-models-to-finished-bases/#findComment-4270038 Share on other sites More sharing options...
M@verik115 Posted January 6, 2016 Share Posted January 6, 2016 I use superglue. It has yet to fail me. Link to comment https://bolterandchainsword.com/topic/317896-glueing-models-to-finished-bases/#findComment-4270041 Share on other sites More sharing options...
AlphariusOmegon108 Posted January 6, 2016 Share Posted January 6, 2016 Finished over 5 armies with bases painted seperatly, just use super glue, works like a charm Link to comment https://bolterandchainsword.com/topic/317896-glueing-models-to-finished-bases/#findComment-4270141 Share on other sites More sharing options...
Ovidius Incertus Posted January 6, 2016 Share Posted January 6, 2016 I pin every mini to its base. Ditto the above comment that I place the mini on the base before basing materials are put down so it doesn't look like it's floating, then removed and painted before being reattached after painting. Link to comment https://bolterandchainsword.com/topic/317896-glueing-models-to-finished-bases/#findComment-4270188 Share on other sites More sharing options...
K0rtmer Posted January 6, 2016 Share Posted January 6, 2016 I use superglue and actually glue unpainted models on unpainted bases first, then break them apart, paint them separately, and glue everything back together at the end of the day. (Occasionally that requires most minor touch-ups.) That way I get to build the model on its base, which I find helpful, and have the benefit of getting to paint both separately. Link to comment https://bolterandchainsword.com/topic/317896-glueing-models-to-finished-bases/#findComment-4270239 Share on other sites More sharing options...
OrangeBob Posted January 6, 2016 Author Share Posted January 6, 2016 I will try both of the methods. This might finally get me to try pinning without having to do anything too tricky. Nice Death Guard, anselneo! Link to comment https://bolterandchainsword.com/topic/317896-glueing-models-to-finished-bases/#findComment-4270278 Share on other sites More sharing options...
JGeils81 Posted January 12, 2016 Share Posted January 12, 2016 Ive been making the base and the model separately, and then painting. I drill the hole in their foot and test on the base where I want them to stand. then add the pin with superglue to the foot, its long enough to go through the base(GW Base) then drill through the base...I glue it in place on the bottom then cut off the extra. Just one way of doing it I suppose Link to comment https://bolterandchainsword.com/topic/317896-glueing-models-to-finished-bases/#findComment-4274483 Share on other sites More sharing options...
