Doomsday ark measurements question
Hi
I'm thinking about a possible base model to use for a kitbash conversion type thing. For the moment I feel like a necros doomsday ark would do the job but I'm not sure it it scales propperly with the other kits involved.
Could somebody that has a doomsday ark give me a measurement of how much vertical room there is in the command section of the ark. Specifically the distance from the mount of the command chair (lets say from the middle of the four prongs) to contact with the arch (ignore the spine, I'll probably cut that off anyway).
So vertical clearance in the command section of the arc without any of the chair parts, spine in the arch or control panel.
An illustration (original image by http://jimbren1.deviantart.com/)
https://goo.gl/photos/9gR1orhk2p5bNcCv7)
Thank you kindly!
Possessed necron tech. So quite xenos and quite heretical but it'll def have at least 10 bolters. No chainswords though, so I guess ymmv
I cant say exactly what till turn out to be (if I even ever build it) as I dont know myself other than possessed necron ark with imperial tech sticking out of it (cfr obliterators but way bigger?)
If thats not ok here then sorry and bye, I suppose.
