Land Raider Proteus conversions?
Charlo
You could just use the normal Land Raider. The Proteus is the Deimos (I think) Pattern, so there's no real reason you can't use the Standard Raider. Gluing the front shut, and putting something like a cheap bits shop bought Leman Russ Dozer in front should be enough. Perhaps going so far to remove the top bit of the Assault Ramp, so that the angle between the assault ramp and the ground is more obtuse rather than acute.
I did a LR Achilles conversion using some spare spartan tracks i got off evay. Im doing another as a proteus using spare tracks and a battered mkiib kit off the same site.
If you got some spare plastic card about, you can make a copy of the front panel from an achilles to replace the assault ramp. It'd work on standard LR, then in the HB turret replace it with some optics. There pictures of my conversions on instagrsm under same name.
Awesome stuff. I have one old school RT era LR but it is a bit tiny!
For the price they often go for on eBay (in awful condition) it may end up cheaper to convert two normal ones.
Plus I figure if I go IH they have a good relationship with Mars so would get some of that pattern stuff!
You can convert standard raiders to proteus. Buy extra landraider tank threads and cut the top slits.
Plasticard the front hatch into a flat pannel. And you can cut the sponsons so they fit on top of one another instead of side by side.
Well, if you cant pick ip one cheap on ebay, you could use the sponsons off a storm raven/eagle thing. That hold the hurricane bolter. That computer picture above, the doors are flat to the hull, youd just need to make a shoulder above it.
I think 30k models allow you to go crazy with conversions, as theres more scope than 40k dogma.
The Mk. IIb is awesome. I just finished putting mine together last week... Machinator of Blood & Skulls Industries on eBay sells tracks for the Land Raider that resemble the Proteus / Spartan / Sicaran. They look great.
http://i64.photobucket.com/albums/h169/DuskRaiderXIV/IMAG0847_zpsig70scij.jpg
BTW, I've seen converted Proteus which had the Phobos Land Raider assault ramp added to the front... looks great.
