Captain General Posted January 19, 2016 Share Posted January 19, 2016 OK, just finished air brush painting my warhound, now I have to do some touch-up work with the same color, but, I had to thin it to spray, now I need to thicken it back up to brush/dab some spots. Is there anyway to thicken the paint? CG Link to comment https://bolterandchainsword.com/topic/318332-thickening-paint/ Share on other sites More sharing options...
Carlson793 Posted January 19, 2016 Share Posted January 19, 2016 Pour some into an open container and let it sit until it 'air dries'/the moisture in it evaporates a bit? Link to comment https://bolterandchainsword.com/topic/318332-thickening-paint/#findComment-4279529 Share on other sites More sharing options...
sibomots Posted January 20, 2016 Share Posted January 20, 2016 OK, just finished air brush painting my warhound, now I have to do some touch-up work with the same color, but, I had to thin it to spray, now I need to thicken it back up to brush/dab some spots. Is there anyway to thicken the paint? CG I think there are mediums you can add to the paint to thicken it back up. Liqutex makes some mediums that can 'gel' it back to a thicker fluid. The other way I was going to suggest that might take a long time is to leave the thin paint in a bottle, capped (no air). Let it settle. Let it separate and then eye-dropper lift off the thin liquid (water) off the top. it would be nice to use a simple centrifuge that would help speed up the process ? Link to comment https://bolterandchainsword.com/topic/318332-thickening-paint/#findComment-4280151 Share on other sites More sharing options...
Imren Posted January 21, 2016 Share Posted January 21, 2016 Vallejo have this retarder medium found on this page: http://www.acrylicosvallejo.com/en_US/model-paints/auxiliary-products/3 That thickens the paint a lot when used. The drawback is (doesn't necessarily need to be) that it slows down the drying time. But it works very well as thickener as well. Link to comment https://bolterandchainsword.com/topic/318332-thickening-paint/#findComment-4280763 Share on other sites More sharing options...
