ElectricPaladin Posted January 21, 2016 Share Posted January 21, 2016 Maybe it's my ADHD acting up, but it really irritates me that the cannon component of a Thunderfire Cannon team doesn't have a base. Grr. Can anyone give me any advice on which base size suits the model, so that I can order it, and have both the gunner and the cannon on a base as it should be. Thanks. Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/ Share on other sites More sharing options...
Cpt_Reaper Posted January 21, 2016 Share Posted January 21, 2016 Don't forget if the thunderfire cannon itself is destroyed the Techmarine can run around. Maybe cut out a part of the cannon's base? Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4280588 Share on other sites More sharing options...
ElectricPaladin Posted January 21, 2016 Author Share Posted January 21, 2016 Don't forget if the thunderfire cannon itself is destroyed the Techmarine can run around. Maybe cut out a part of the cannon's base? Hm... that's actually a really good idea. I could use a pretty huge base, like a flyer's base, with a cut-out for the techmarine to sit in. Maybe use magnets so it's easy to move the whole thing around as a unit... Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4280591 Share on other sites More sharing options...
Cpt_Reaper Posted January 21, 2016 Share Posted January 21, 2016 You wouldn't even need it that big. A standard dreadnought-sized base should do the trick for both. Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4280611 Share on other sites More sharing options...
Jarl of Wulfen Posted January 21, 2016 Share Posted January 21, 2016 Here is in earlier thread related to this topic http://www.bolterandchainsword.com/topic/316998-basing-artillery/?view=getnewpost Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4280810 Share on other sites More sharing options...
ElectricPaladin Posted January 21, 2016 Author Share Posted January 21, 2016 You wouldn't even need it that big. A standard dreadnought-sized base should do the trick for both. Nah, I checked that out. The thunderfire cannon has significant overhang to the front and the back. While that's not a rules issue, I think it looks pretty awful. I'm going to go to the trouble of putting this thing on a base, I want it to look good. Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4280866 Share on other sites More sharing options...
Halandaar Posted January 21, 2016 Share Posted January 21, 2016 What about the 90x52 Oval base? I think that's your "monstrous cavalry" sized one. Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4280905 Share on other sites More sharing options...
AndrewChristlieb Posted January 22, 2016 Share Posted January 22, 2016 I've seen a few of them on 60mm bases and it looks pretty stupid since the feet hang off. I'd probably swing for a flyer base to make sure you have room for it. I don't know about actually having the Tech on the same base though, even detachable, since I often adjust their position relative to each other in order to benefit from the 2+ save on the tech. http://lh5.ggpht.com/_-HZLorI1B0w/TJU5iLEzBQI/AAAAAAAAL_g/V4ymy92bl2Y/s800/Thunderfire%20cannon%20on%20dreadnought%20base.jpg Just don't... Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4281330 Share on other sites More sharing options...
Naminé Posted January 22, 2016 Share Posted January 22, 2016 Aren't some of the new fantasy AoS bases the same size but oval? They look like they'd fit you pretty well Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4281494 Share on other sites More sharing options...
Halandaar Posted January 22, 2016 Share Posted January 22, 2016 Aren't some of the new fantasy AoS bases the same size but oval? They look like they'd fit you pretty well They're in use in 40k too; What about the 90x52 Oval base? I think that's your "monstrous cavalry" sized one. ^ The one I mentioned earlier I believe is the new standard base size for Bloodcrushers in both systems, for example. The below chart is really handy: (Source) http://i.imgur.com/f7mjOGn.png Having seen the Thunderfire on a 60mm, it might be that the 90x52 oval is too narrow and maybe the 105x75 (the one that comes with Ironstriders, Ghostkeels and Carnifexes) might be better. Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4281528 Share on other sites More sharing options...
Jarl of Wulfen Posted January 22, 2016 Share Posted January 22, 2016 If you look in the earlier thread I mention, I have a link to a pick of the TFC on a 105x75 base Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4281690 Share on other sites More sharing options...
Xenith Posted January 22, 2016 Share Posted January 22, 2016 I hate to tell you, but your tanks don't have bases either. Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4281796 Share on other sites More sharing options...
ElectricPaladin Posted January 22, 2016 Author Share Posted January 22, 2016 I hate to tell you, but your tanks don't have bases either. BUT IT'S NOT A TANK!!! But seriously. It's got infantry rules; it ought to be on an infantry base. Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4281803 Share on other sites More sharing options...
Kaedes Nex Posted January 23, 2016 Share Posted January 23, 2016 Artillery used to be AV10 vehicles. Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4282329 Share on other sites More sharing options...
CaptainHelion Posted January 23, 2016 Share Posted January 23, 2016 Well, I'm glad that changed. Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4282345 Share on other sites More sharing options...
krakenfiend Posted January 28, 2016 Share Posted January 28, 2016 I put my Attack bikes and my Thunderfire Cannon on 80mm bases. I tried the 60mm but the overhand was too great. I found that the Thunderfire sits on the 80mm very well...it is close to the edge but does not hang off the base. I'll post a pic of what it looks like when I get home from work. I bought 9, 80mm bases...enough for 6 attack bikes and 3 thunderfires... krakenfiend Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4287529 Share on other sites More sharing options...
The_Chaplain Posted January 28, 2016 Share Posted January 28, 2016 Having seen the Thunderfire on a 60mm, it might be that the 90x52 oval is too narrow and maybe the 105x75 (the one that comes with Ironstriders, Ghostkeels and Carnifexes) might be better. Yep, it needs the 105X70mm base. Here is one of my thunderfires on that base compared to a rapier on a 90X52: https://c2.staticflickr.com/2/1604/24048336454_5c0c4c2283_z.jpg B&C doesnt like the file extension, otherwise id just post the pic. Link to comment https://bolterandchainsword.com/topic/318387-base-for-a-thunderfire-cannon/#findComment-4287670 Share on other sites More sharing options...
