War Angel Posted January 21, 2016 Share Posted January 21, 2016 Someone at my local store was saying that there's these bases that are hollow and cut in half so that you can put them together around your existing bases in order to take them from the old size to the new size. Does anyone know if these are real? Link to comment https://bolterandchainsword.com/topic/318396-snap-on-base-extensions/ Share on other sites More sharing options...
Carlson793 Posted January 21, 2016 Share Posted January 21, 2016 There are a number of companies producing these (plus an independent operation or two). Check the sites in The Forges of Mars thread - I know I added one with the 32mm extension bases yesterday, and have added a few more over time, but can't remember which sites had them off the top of my head (wish I could be more help than that). EDIT: Google "32mm base adaptor" Link to comment https://bolterandchainsword.com/topic/318396-snap-on-base-extensions/#findComment-4280930 Share on other sites More sharing options...
War Angel Posted January 21, 2016 Author Share Posted January 21, 2016 Thanks! Link to comment https://bolterandchainsword.com/topic/318396-snap-on-base-extensions/#findComment-4280949 Share on other sites More sharing options...
ElectricPaladin Posted January 21, 2016 Share Posted January 21, 2016 I haven't seen any that are too slick. You're probably going to have to do some greenstuffing and rebasing... thought it's still going to be easier and cheaper than just ripping off the bases and replacing them. Link to comment https://bolterandchainsword.com/topic/318396-snap-on-base-extensions/#findComment-4280984 Share on other sites More sharing options...
Carlson793 Posted January 21, 2016 Share Posted January 21, 2016 I've added a section for 32mm Adapters to the Forges of Mars thread (see my sig). Link to comment https://bolterandchainsword.com/topic/318396-snap-on-base-extensions/#findComment-4280991 Share on other sites More sharing options...
