hopkins Posted January 24, 2016 Share Posted January 24, 2016 Need some help with lists, themed around Golg and Terminators to start with, before bringing in the big boys, primarch and tanks at bigger points games Starting at 1k points, before moving to 2k and finally 3k This is what I have in mind so far, and not looking for optimal netlists, just fitting the theme, nothing has been built with weapons attached I'm all about deep-striking, spear tips, alpha strikes etc, as I get bored playing gunline Golg 5 x Tyrant Siege Terminators 5 x Tyrant Siege Terminators 1 x Contemptor w/ DCCW & Chainfist 10 x Legion Cataphractii Terminators 5 x Legion Cataphractii Terminators 10 x Iron Havocs with Autcocannons Spartan Sicaran Battle Tank Perturabo Thanks in advance Link to comment Share on other sites More sharing options...
Vastopol Posted February 29, 2016 Share Posted February 29, 2016 Hi Hopkins, Not sure if this helps but are you aware of under the new rules its no-longer to run Tyrant Siege Terminators as Troop, as Pride of Legion effects Elite based Terminators, I would strongly suggest as a strong start to get hold of 30, MK4 tactical marines and build those as 2 15 man squads with a Sergeant in AA, MB and a Power Weapon, That is a strong start to a 1k army supported with 'Golg' as a Preator Character with the Sicaran, from there I would look to pick up two Apothcary's to support the tactical squads and from there just branch out, Hope this helps and is relevant to your needs, Iron Within, Iron Without ! Link to comment Share on other sites More sharing options...
