LR Achilles Alpha or Vanilla Achilles
Hello experts!
Am i missing something about the achilles alpha?
Im a IF player so i like the achilles for the fluff, now both versions have access to shatter shells it would seem, the main difference being choom or melta side weapons. But the alpha can swap out choom for meltas, alpha comes with galvanic drive which makes you re roll DTT, but you can buy auxiliary drive for standard achilles which appears to be better as it allows a immoblised result to be repaired.
Both have the same ferromantic invulnerability, and a standard achilles comes in cheaper than an alpha.
What am i missing? I think the standard one is better as i can put it in a squadron with a proteus to support it, and put a havoc launcher on it for same price, and top it off use one HS slot.
Ive magnetised the weapons, just in case. And obviously the choom looks better, but game wise?
I know amoured ceramite is about, but melta is good at turning ap 2 men into slag!
It is, but the mortar only goes up to ap3, and 8 twin linked S6 deflag shots still hurt power armour and what frag shells will hurt too. Better synergy among weapons.
Does it have machine spirit though? That could be a case for Melta (if you're insaaaaane)
I got an alpha simply because it has my favourite weapons - culverin choomy goodness and a quad mortar. Machine spirit the mortar and choom infantry. It's joined my twin twin linked choomtemptor and the leviathan which also has choom. Choom, choom, choom, shake the room!
Get the Alpha since it has the volkite sponsons. You can magnitze them at that point so you can switc it up.
It also unequivolcally has Shatter Shells which combined with Machine Spirit and Multi melta to make it a good unit.
One that has bugged me is that Enhanced Ferromantic Rites do nothing more than Ferromantic Invulnerability, or why Achilles (Beta?) has Armoured Ceramite. So you're paying 50pts to swap MM to Culverins and gain access to Tank Killing Rounds (after possibly swapping away MM for Infantry shredding Volkites).
A bit naff.
As they have a transport capacity (6)
if they are transporting an elite or fast attack choice, do you think they could they outflank using maru skara? I don't think it's really clear, but maybe that's a 'between the lines' thing.
I have the kit to put together I just wondered if it was worth play testing it before I do.
I'll have to check, but I think it only confers if they have Outflank, or are Dedicated Transports.
In general, 'between the lines' is a thinky veiled 'it doesn't say i can't', something I've certainly played on in the past.
It annoys me as well it is not an option, however, for a Command Sqiad to not be able to take it.
Its actually a 25pt Difference between both Variants and that cost only gives you integrated Dozer Blades and the option to swap out to Culverin Sponsons.
Where the rule of cool is concerned, this isn't much of an issue.
...they also both have Armoured Ceramite standard and screw over Melta more in addition to "LOLNOPE"ing Lance Weapons.
The -1 to the damage table also means Ap1 is blowing you up on a 6 instead of 5 (unless D) and Alpha Legion Shenanigans are toned back down to a +2 to the chart.
It would make sense that a command squad could take it as the fluff states it was favoured by command squads.
With the 25 pts difference, you can buy an auxiliary drive and a havoc launcher to make it the same if not better (?).
I like the choom better as rule of cool, but in my army those few points make a difference.
I want to love the volkites on the model but i just dont think its 25 points better.
In a world were armoured ceramite is an option on all valuable targets, the choom makes it better at mauling infantry
For AT there is better choices, sicaran ventor & vindi destroyer for example.
But as heavy tank with stopping power the achilles is better than a standard LR, as thats being ecliped by the spartan as an assault tank. But thats for another post.
Thanks for your views.
  • 2 weeks later...
  • 4 weeks later...
I apologise for the threadromancy,
But now that the quad mortar has been "nerfed" (or in my view made better) with different ammo types will this affect the achilles or achilles alpha?
Threadromancy returned!
Legiones Astartes Quad Mortar was updated, nothing else. So we still have frag & shatter as per standard. This applies to Solar Auxilia quad mortars too I guess.
It seems that multi-meltas are well suited to Covenant of Fire Salamanders. Twin-linked and master-crafted multi-meltas with shatter shells to pelt TEQs sounds like a winning combination in my book.
