Kaspar Posted January 26, 2016 Share Posted January 26, 2016 Which kind of primer do you use for Forgeworld resin??? Thx Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/ Share on other sites More sharing options...
Brother Callius Posted January 26, 2016 Share Posted January 26, 2016 Can't recomend Vallejo grey spray primer enough, but always after a layer of purity seal ++EDIT: Whoops, forgot to add ''enough'' so it souned like I hated Vallejo ++ Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285247 Share on other sites More sharing options...
Jarl of Wulfen Posted January 26, 2016 Share Posted January 26, 2016 I used the GW black and has no problem. Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285332 Share on other sites More sharing options...
Kaspar Posted January 26, 2016 Author Share Posted January 26, 2016 Can't recomend Vallejo grey spray primer enough, but always after a layer of purity seal http://1.1.1.1/bmi/image.bolterandchainsword.com//public/style_emoticons/default/thumbsup.gif ++EDIT: Whoops, forgot to add ''enough'' so it souned like I hated Vallejo http://1.1.1.1/bmi/image.bolterandchainsword.com//public/style_emoticons/default/ohmy.png++ Realy, first a layer of purity seal and then Vallejo grey primer??? Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285348 Share on other sites More sharing options...
Carlson793 Posted January 26, 2016 Share Posted January 26, 2016 Krylon. Only time I've had a problem with it is when I forget to clean the resin beforehand. Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285376 Share on other sites More sharing options...
m_r_parker Posted January 26, 2016 Share Posted January 26, 2016 Undercoat is always dependant on what colour you're looking to go to. Grey is a safe bet, but for real dark colours I go with a Chaos Black. However, all ForgeWorld is sprayed with Purity Seal first, and I've not had any issues with paint flaking off since. Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285416 Share on other sites More sharing options...
Brother Callius Posted January 26, 2016 Share Posted January 26, 2016 Can't recomend Vallejo grey spray primer enough, but always after a layer of purity seal http://1.1.1.1/bmi/image.bolterandchainsword.com//public/style_emoticons/default/thumbsup.gif ++EDIT: Whoops, forgot to add ''enough'' so it souned like I hated Vallejo http://1.1.1.1/bmi/image.bolterandchainsword.com//public/style_emoticons/default/ohmy.png++ Realy, first a layer of purity seal and then Vallejo grey primer??? Yeah I always give FW pieces a good soapy scrub then a varnish to seal off any residue release agent and finally grey primer. I had some issues with a Mk. III heavy support squad where the mold release just wouldn't come off and my paint would flake in big chunks, even with primer. So after that I always use purity seal before priming just to be on the safe side and I haven't had any issues since. Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285439 Share on other sites More sharing options...
Kaspar Posted January 26, 2016 Author Share Posted January 26, 2016 Thanks for your replies so far. To clean the resin you use only soap or chemicals??? Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285456 Share on other sites More sharing options...
CplHicks Posted January 26, 2016 Share Posted January 26, 2016 I've used halford plastic primer before. But like previous have said can't go wrong with the chaos black spray after a soapy wash. Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285510 Share on other sites More sharing options...
Slips Posted January 26, 2016 Share Posted January 26, 2016 Forgeworlds download section has a "working with resin" guide and GW has also made a video where they show the steps to assembling a Spartan. All the basic info you need should be found within ^_^ I would like but...mobile. Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285538 Share on other sites More sharing options...
Atia Posted January 26, 2016 Share Posted January 26, 2016 Forgeworlds download section has a "working with resin" guide and GW has also made a video where they show the steps to assembling a Spartan. All the basic info you need should be found within I would like but...mobile. https://www.youtube.com/watch?v=4UNAjik9S80 and the working with resin guide: http://www.forgeworld.co.uk/resources/fw_site/fw_pdfs/Modelling/Working_With_Resin_Models.pdf Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285549 Share on other sites More sharing options...
Lord Blackwood Posted January 26, 2016 Share Posted January 26, 2016 Forgeworlds download section has a "working with resin" guide and GW has also made a video where they show the steps to assembling a Spartan. All the basic info you need should be found within I would like but...mobile. I GOTCHU Nvm Atia got there first XD Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285552 Share on other sites More sharing options...
Slips Posted January 26, 2016 Share Posted January 26, 2016 Forgeworlds download section has a "working with resin" guide and GW has also made a video where they show the steps to assembling a Spartan. All the basic info you need should be found within I would like but...mobile. I GOTCHU Nvm Atia got there first XD #REKT Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285560 Share on other sites More sharing options...
Brother Callius Posted January 27, 2016 Share Posted January 27, 2016 Thanks for your replies so far. To clean the resin you use only soap or chemicals??? You're welcome, for the wash I just use warm (but not scolding) water with dishwashing liquid and a old toothbrush for scrubbing, then I rinse in clean cold water. The video from GW themselves are actually pretty good, so I would give that a looksie if i'ts the first time you're working with FW resin. Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4285717 Share on other sites More sharing options...
Dantay VI Posted February 3, 2016 Share Posted February 3, 2016 Is the Vallejo polyurethane primers, which you spray through an airbrush any good? I just got an airbrush as a gift and have no ideas about what is good or not. I am getting a cleaning kit for it, but wondered if the Vallejo primer would be a good buy. I am also considering getting the spray matte varnish too, would that be good for sealing up FW resin. I have built a few FW things and washed them, but assumed the paint flake/chip was me overhandling them. :) Link to comment https://bolterandchainsword.com/topic/318553-primer-for-resin/#findComment-4292766 Share on other sites More sharing options...
