kalenein Posted February 1, 2016 Share Posted February 1, 2016 I am pretty sure I cant do this but I wanted to ask anyway.. but if put an assault squad in a Storm Raven and pay the 10 points for the locator beacon my assault squad cant take advantage of that if they deep strike out of the storm raven via skys of fury right? So basically the turn my SR comes on the board I cant just fly it up point blank in front of a Leman Russ and drop three melta guns on top of him without scattering can I.. Link to comment Share on other sites More sharing options...
Riot Earp Posted February 1, 2016 Share Posted February 1, 2016 Dies not work. PG 106 BA Codex. The bearer must habe been on the battlefield at the Start of the turn. Link to comment Share on other sites More sharing options...
Quixus Posted February 1, 2016 Share Posted February 1, 2016 You cannot do that on the turn the Stormraven comes in from reserve. Later it is possible if you designate a point for skies of fury that is within 6" of the stormraven (and along the line the stormraven moved). It also works if the Stormraven was deployed on a Skyshield Landing Pad with the Ready for Takeoff upgrade. Link to comment Share on other sites More sharing options...
kalenein Posted February 1, 2016 Author Share Posted February 1, 2016 Thanks for the answers looks like I can make use on the second turn that the SR is on the board. As a side question assume an opponent you play against fairly often always brings Pask in an punisher cannon lemen russ with orgyns in front for cover. what is the best way you can think of to tackle this target? Link to comment Share on other sites More sharing options...
Quixus Posted February 1, 2016 Share Posted February 1, 2016 As a side question assume an opponent you play against fairly often always brings Pask in an punisher cannon lemen russ with orgyns in front for cover. what is the best way you can think of to tackle this target? Fly over the tanks and shoot them in the rear, drop pod behind them, hang a Furioso on the stormraven. With the Magna Grapple the dreadnought never has to roll a dangerous terrain test while getting out via Skies of Fury. Link to comment Share on other sites More sharing options...
Doctor Perils Posted February 1, 2016 Share Posted February 1, 2016 Have you considered Scout Bikers with locator beacon: They're fast enough to get them where you want them, they're relatively cheap and tough... Link to comment Share on other sites More sharing options...
Xenith Posted February 1, 2016 Share Posted February 1, 2016 As per Quixus, put the assault marines in a drop pod instead, pod into space near. If the ogryns are blocking, would a Fear Librarian help? Link to comment Share on other sites More sharing options...
