War Angel Posted February 9, 2016 Share Posted February 9, 2016 I want to make a street for my imperial knights base. Any tips or help. Link to comment https://bolterandchainsword.com/topic/318998-how-can-i-make-asphalt-from-green-stuff/ Share on other sites More sharing options...
Jarl of Wulfen Posted February 9, 2016 Share Posted February 9, 2016 You might be better off using the astrogranite texture paint with a heavy null oil wash Link to comment https://bolterandchainsword.com/topic/318998-how-can-i-make-asphalt-from-green-stuff/#findComment-4300214 Share on other sites More sharing options...
battle captain corpus Posted February 9, 2016 Share Posted February 9, 2016 There are quite a few YouTube vids to browse through. Personally I would try: - quite thick layer of green stuff smoothed flat while wet - roll a small pebble or stone over surface with gentle pressure to create a textured base layer - using a wet hobby knife score lines to resemble brick work or cobbles - leave to dry for at least 5 hours - using PVA glue add small areas of sand to represent rubble etc. Just my 2 cents. BCC Link to comment https://bolterandchainsword.com/topic/318998-how-can-i-make-asphalt-from-green-stuff/#findComment-4300381 Share on other sites More sharing options...
SW1 Posted February 9, 2016 Share Posted February 9, 2016 I'd not bother with the gs unless there's holes to fill in. Get a smoothing surface and then apply fine sand to the base with PVA. Seal with a watered down PVA. Leave to dry a few days. And then hit with a black and then a very very light drybrush with a dark/medium grey. Link to comment https://bolterandchainsword.com/topic/318998-how-can-i-make-asphalt-from-green-stuff/#findComment-4300387 Share on other sites More sharing options...
Bung Posted February 9, 2016 Share Posted February 9, 2016 Simplest Method of all would be to use some fine sanding paper. Just cut it like you need it and glue it on the base. Link to comment https://bolterandchainsword.com/topic/318998-how-can-i-make-asphalt-from-green-stuff/#findComment-4300868 Share on other sites More sharing options...
old git Posted February 9, 2016 Share Posted February 9, 2016 Agreed on the above. A medium to fine grain wet and dry glass paper would be much easier. Link to comment https://bolterandchainsword.com/topic/318998-how-can-i-make-asphalt-from-green-stuff/#findComment-4300888 Share on other sites More sharing options...
Retributis Posted February 10, 2016 Share Posted February 10, 2016 For my bases I use Agrellan earth re-primed to black, then dry-brushed with varying greys and washed heavily with Nuln Oil. Link to comment https://bolterandchainsword.com/topic/318998-how-can-i-make-asphalt-from-green-stuff/#findComment-4301664 Share on other sites More sharing options...
Brother Pheidias Posted February 10, 2016 Share Posted February 10, 2016 For raised asphalt, cork is also an option. Bonus points for being able to dig holes into it that realistically resemble potholes/craters from lower calibre weaponry. Link to comment https://bolterandchainsword.com/topic/318998-how-can-i-make-asphalt-from-green-stuff/#findComment-4301710 Share on other sites More sharing options...
battle captain corpus Posted February 10, 2016 Share Posted February 10, 2016 Tada! BCC Link to comment https://bolterandchainsword.com/topic/318998-how-can-i-make-asphalt-from-green-stuff/#findComment-4301843 Share on other sites More sharing options...
War Angel Posted February 10, 2016 Author Share Posted February 10, 2016 Thanks guys Link to comment https://bolterandchainsword.com/topic/318998-how-can-i-make-asphalt-from-green-stuff/#findComment-4302014 Share on other sites More sharing options...
