Using modelling clay on bases
I know little about modelling clay.  I have a fair number of large scenic bases to make for upcoming projects and I am seeking a way to create terrain features, mounds, craters, etc. on them.  I've used GS in the past, but this can get really expensive when you're talking about Knight- or Titan-sized bases.  Even if I use sprue as filler, still lots of expensive GS wasted.
So are there any modelling clays that can fill the bill for cheaper?  I know polymer clays can be hardened in an oven, but if they're attached to a base, won't that melt the base itself?  I'm seeing temperatures of around 265 F/130 C.  Will a plastic base survive those temperatures and/or give off toxic fumes?  Wiki is telling me that polystyrene plastic melts around 460 F/240 C but "decomposes at a lower temperature".
Suggestions?
https://bolterandchainsword.com/topic/319148-using-modelling-clay-on-bases/
I guess the price is pretty equal yeah, though I've always found it easy to work with and great for sculpting 'rough work' that'll be textured etc.
To use less moulding material I've found bulking out bases with bits of sprue and bases etc first then applying clay etc will help.
There's quite a few air dry clays here in the UK, I agree with Brother Chaplain Kage definitely about going to your local hobby store for advice too. :)
BCC
I tried the used sprue...and still ended up using nearly a whole tube's worth of GS, unfortunately. dry.png
I'll look into air drying clays. I figured there might be such a product and upon investigation, I should be able to get it at Michaels or even Walmart.
Thanks for the advice, fratres.
I picked up some Crayola brand air dry clay in white at Walmart.  Huge tub for just over $5 (cheaper than the similar price I found on the same product at Michaels by an order of 4x).
I'll give it a whirl on the two Knights' bases I'm dreaming up now.  I suspect the cure time will be very long, though, since I'm sure it'll end up thick in some spots.
I use DAS which is an air drying clay - costs up to £8 for a half kilo slab and can be carved/drilled/filed once it's hardened as well as being pushed into shape before it goes off.
I'm also using some scenic rock molds (about £9-£10 each) that I'm casting using plaster of Paris to add some scenic details.
Once the clay has dried, add some textured paint, rocks, gravel etc to taste and then go to town with painting (once glues etc have dried)
Haven't got any examples to show (at work and no pics taken anywhere) but it's what GW used to do back in RT & 2nd ed days so you should be able to find examples online somewhere.
Hope that helps :)
I recently used Liquitex modeling putty for my display board. I wouldn't go so far to call it sculptable, but it might be good enough for your purposes. It takes a while to cure if you use it in large amounts, so be prepared to wait a day or two.
