Decal help
Jofus
You're going to hear this from a lot of people, so head to Amazon and get some Microset and Microsol. The 'set helps the decal set into place and softens it a little bit to snuggle into the nooks and crannies, and the 'sol takes that softening and turns it up to 11. You just brush the Microsol on and wait, and it will dissolve the backing film so the decal gets right down into the cracks. Sometimes you need a few coats, and you have to let it dry completely in between coats.
That said, I've never done one over something like detail work that heavy, and I can't say for sure that it would work as well as you want. Maybe someone else can vouch for that bit?
https://bolterandchainsword.com/topic/319171-decal-help/#findComment-4305039
