Mixing paint, what do you use?
When mixing GW paint, what do you use to take the paint out of the pot(s) that are to be mixed? I have tried using everything from pieces of sprue to dip out the paint to a small spoon shaped end of a sculpting tool. Does anyone know of a better way to do this? wacko.png
https://bolterandchainsword.com/topic/319253-mixing-paint-what-do-you-use/
I usually put a few ml of flow improver into the pot, wrap it in a paper towel, and shake it up pretty good. You can then get this out with a disposable pipette (can order these easily, for example) if you are trying to get a specific amount to mix with, or you can simply pour the bottle into another, larger, mixing pot if you need the entire amount.
I've found this usually allows you to get almost all of the paint out.
When mixing GW paint, what do you use to take the paint out of the pot(s) that are to be mixed? I have tried using everything from pieces of sprue to dip out the paint to a small spoon shaped end of a sculpting tool. Does anyone know of a better way to do this? :wacko:
I just use the back of my brush. Works just fine.
Ditto Lucio.  I use toothpicks to dip and to mix.  It is a time consuming affair, though.
You could always transfer your favorite GW paints to dropper bottles.  (Says the guy who has a whole bag of empty dropper bottles but has never put them to use for the very purpose he bought them for....)
Put your GW paints into dropper bottles like the one of Vallejo and other paint brands use. Best way to get your paint to your palette or mixing them.
