JeffTibbetts Posted February 18, 2016 Share Posted February 18, 2016 Hey all. I sprayed some Future gloss over a couple Space Hulk termies to seal them, since they get handled a lot. To dull the paint back down, I sprayed them with a thin coat of Lahmian Medium which worked quite well. Perhaps TOO well. They look just very slightly dusty. I have a 3rd Term I sprayed with Testors Dull Coat which is great, but I prefer to spray through my airbrush. I was thinking it might be possible to add a little touch of 'Ard Coat next time, to bring the matte finish back just a tiny bit. Has anyone ever tried this? If so, what ratio would you suggest? I was thinking of starting with 1 part AC to 3 parts LM, and then thinned as usual. What do y'all think? Link to comment https://bolterandchainsword.com/topic/319405-sealing-with-ard-coat-and-lahmian-medium/ Share on other sites More sharing options...
captainblow Posted February 18, 2016 Share Posted February 18, 2016 I often mix matt varnish with gloss varnish 50-50 to create satin varnish. I have no experience with using matt medium for sealing, but I'd imagine your idea would work just fine. Try it and let us know. Link to comment https://bolterandchainsword.com/topic/319405-sealing-with-ard-coat-and-lahmian-medium/#findComment-4310611 Share on other sites More sharing options...
JeffTibbetts Posted February 18, 2016 Author Share Posted February 18, 2016 Well, the actual sealing is done with the Future, and the matte is just to take the gloss out. 50/50 seems almost too gloss, but who knows? I imagine I'll have to play around with the mix a bit. Link to comment https://bolterandchainsword.com/topic/319405-sealing-with-ard-coat-and-lahmian-medium/#findComment-4310614 Share on other sites More sharing options...
SW1 Posted February 22, 2016 Share Posted February 22, 2016 Out of interest do you use your airbrush for the future? What do you use to clean it with if you do? Can't see varnish going through the airbrush as an easy clean afterwards. Link to comment https://bolterandchainsword.com/topic/319405-sealing-with-ard-coat-and-lahmian-medium/#findComment-4314708 Share on other sites More sharing options...
JeffTibbetts Posted February 22, 2016 Author Share Posted February 22, 2016 I did, yeah, and I've done it before with no issues. It's the gloss of choice for the scale modeling crowd. I cleaned it the same as any other paint: shoot a little water through, then a few drops of airbrush cleaner (I use Tamiya) and then a little more water, then break it all down and clean it in pieces before assembling again. Future is water soluble and cleans up nicely. Link to comment https://bolterandchainsword.com/topic/319405-sealing-with-ard-coat-and-lahmian-medium/#findComment-4314937 Share on other sites More sharing options...
SW1 Posted February 22, 2016 Share Posted February 22, 2016 I did, yeah, and I've done it before with no issues. It's the gloss of choice for the scale modeling crowd. I cleaned it the same as any other paint: shoot a little water through, then a few drops of airbrush cleaner (I use Tamiya) and then a little more water, then break it all down and clean it in pieces before assembling again. Future is water soluble and cleans up nicely. Thanks for the info. I've an airbrush and compressor sat in a box getting dusty. Need to get my head around using it and just do it. :) Link to comment https://bolterandchainsword.com/topic/319405-sealing-with-ard-coat-and-lahmian-medium/#findComment-4315030 Share on other sites More sharing options...
JeffTibbetts Posted February 22, 2016 Author Share Posted February 22, 2016 Yeah, I played around with a cheap one from Amazon first and sort of got the kinks out. I just graduated to a Sotar 20/20 a while back and I'm enjoying it. I still mostly use it for just basecoats and whatnot, but that's partially just because it suits my painting style. Link to comment https://bolterandchainsword.com/topic/319405-sealing-with-ard-coat-and-lahmian-medium/#findComment-4315117 Share on other sites More sharing options...
