NoLats_McGee Posted March 2, 2016 Share Posted March 2, 2016 So massive spoilers for Retribution, but in some fluff it presents Autek Mor hears about quite a major Forge/Manafactorum World named Bodt going rogue, and deploys his warband there in quite the hurry. Despite dooming the planet by shooting its moon into it (seriously), he risks his entire warband by landing and going after some heavily sealed vault. He descends the vault, insisting on doing it alone. He comes out looking quite battered and burnt, and emerges with a 'large stasis casket' which is covered in 'the sigils of the Emperor's gene-wrights'. After getting this he immediately leaves, right as the planet goes full Majora's Mask. My question is what could be worth all that much trouble? It only gets more mysterious when you look at the actual description of what he stole. Some of my friends think it could be the corpse of a lost Primarch. If this is indeed the case then what exactly would he plan on doing with it? Could there be secret chimeric/full-blood XI and II legion marines in Autek's little band of misfits? Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/ Share on other sites More sharing options...
Charlo Posted March 2, 2016 Share Posted March 2, 2016 Either that or its some sort of perfect blueprint for Astartes/ custodes etc! Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323750 Share on other sites More sharing options...
depthcharge12 Posted March 2, 2016 Share Posted March 2, 2016 The first question would be, why the hell would it be in World Eater hands in the first place? (Bodt is their staging world) It's possible that the casket contains a dead thunder warrior as the Workd Eaters had been sent to eradicate the remaining ones on an asteroid, so it's likely someone kept a souvenir from that. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323752 Share on other sites More sharing options...
GhostMalone Posted March 2, 2016 Share Posted March 2, 2016 But to go that full on it has to be something bigger than a thunder warrior etc. Maybe it's a failed primarch not lost or anything just genetically failed and the gene seed was never utilised as most legions needed their primarch to increase the success rate, maybe he has a cache of unused Geneseed Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323756 Share on other sites More sharing options...
depthcharge12 Posted March 2, 2016 Share Posted March 2, 2016 Or maybe it's the Emperor's secret recipe for his Imperium IPA. Bypasses whatever type of alcohol processing organs you may have. "Imperium IPA. The Emperor's Finest." Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323778 Share on other sites More sharing options...
Nakuth Posted March 2, 2016 Share Posted March 2, 2016 Or maybe it's the Emperor's secret recipe for his Imperium IPA. Bypasses whatever type of alcohol processing organs you may have. "Imperium IPA. The Emperor's Finest." Imperium IPA; the true double IPA! Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323780 Share on other sites More sharing options...
Marshal Rohr Posted March 2, 2016 Share Posted March 2, 2016 Its probably whatever technology the World Eaters had been using to push the limit on how fast a legionary can be created. IIRC, Its been mentioned in almost every FW book that statistically, when compared to normal human-to-legionary transformation time, the World Eaters casualty figures would've rendered them extinct but they have access to some technology that allows them to keep pace with their losses. Its heavily implied in the 40K universe, Krieg Guardsmen are created the same way, but from test tube to adulthood in a very short time. Just a shot in the dark though. If I was Mor, I would look for a magic formula to grow legionaries. Between that and the Iron Hands brutal doctrine, Im wondering if we won't see thousands of brainwashed, growth accelerated iron hands grinding across the traitor lines in the next few book. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323815 Share on other sites More sharing options...
depthcharge12 Posted March 2, 2016 Share Posted March 2, 2016 Wasn't it Angron that streamlined the process and upped the hypno indoctrination? I believe it was mentioned in Betrayal in the WE section. The World Eater gene seed is also surprisingly receptive too, almost on the level of stability of the Dark Angels, Ultramarines, and Sons of Horus. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323824 Share on other sites More sharing options...
N1SB Posted March 2, 2016 Share Posted March 2, 2016 This is very interesting. My question is what could be worth all that much trouble? It only gets more mysterious when you look at the actual description of what he stole. Some of my friends think it could be the corpse of a lost Primarch. If this is indeed the case then what exactly would he plan on doing with it? Could there be secret chimeric/full-blood XI and II legion marines in Autek's little band of misfits? Those are all good questions and I don't know, and look forward to ideas. What I do know now is something I've discovered with 30k: the 30k narrative does NOT end with the boarding of the Vengeful Spirit and the death of Horus. Previously, what held me off from 30k was this preconception I had that it was a closed-off story, something not worth investing in because it's a done deal. All of this is very, very interesting, thanks for sharing this, will look more into Book VI. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323830 Share on other sites More sharing options...
NoLats_McGee Posted March 2, 2016 Author Share Posted March 2, 2016 One thing I actually did want to include in my force (obviously i'm doing post-Istvaan Autek and friends) is a contingent of 'mass-produced' Iron Hands who have been rapidly grown and psycho-indoctrinated. Whether these are truly Iron Hands or actually World Eaters/Chimeric/lost legion is still a mystery to me. How would you guys go about modelling this? Specific marks of armour, features, etc? Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323866 Share on other sites More sharing options...
b1soul Posted March 2, 2016 Share Posted March 2, 2016 This question shall never be answered. It's just a story hook Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323872 Share on other sites More sharing options...
Marshal Rohr Posted March 2, 2016 Share Posted March 2, 2016 One thing I actually did want to include in my force (obviously i'm doing post-Istvaan Autek and friends) is a contingent of 'mass-produced' Iron Hands who have been rapidly grown and psycho-indoctrinated. Whether these are truly Iron Hands or actually World Eaters/Chimeric/lost legion is still a mystery to me. How would you guys go about modelling this? Specific marks of armour, features, etc? Personally, to represent Dorn's accelerated inductees I use plain mark 3 armor. The only difference is the occasional ablative strike plate on the over the grill of the mark 3. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323874 Share on other sites More sharing options...
NoLats_McGee Posted March 2, 2016 Author Share Posted March 2, 2016 Part of me wants to use MK V, given its reputation for being hastily thrown together and it's relatively rough and brutal look. The 'Gerasene Host' of mass-produced marines in Book 6 comes to mind. I'm also thinking there wouldn't be much in the way of bionics or the classic Iron Hands aesthetic (cog teeth, chains, super-played armour etc) given they're relatively 'new' and probably rather lacking in personality. Even more interesting is how you'd approach their personality and temperament.. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323878 Share on other sites More sharing options...
Marshal Rohr Posted March 2, 2016 Share Posted March 2, 2016 I'm partial to Borg drones myself :D Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323893 Share on other sites More sharing options...
Dantay VI Posted March 2, 2016 Share Posted March 2, 2016 Bodt: If it has the Emperors genewrights seal, it is pre-heresy. Could it be a genetic sample from the Primarch project which saw the creatin of Primarchs and Astartes? A back-up to the genetic materials on Terra? Mor is looking for a way to clone Ferrus Mannus Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323913 Share on other sites More sharing options...
Athrawes Posted March 2, 2016 Share Posted March 2, 2016 Bodt: If it has the Emperors genewrights seal, it is pre-heresy. Could it be a genetic sample from the Primarch project which saw the creatin of Primarchs and Astartes? A back-up to the genetic materials on Terra? Mor is looking for a way to clone Ferrus Mannus As odd as it may sound, I actually like having a hint that perhaps Autek Mor Can clone Ferrus Manus. Not for the lore as it cheapens the tragedy of his death, but that it allows an Iron hands Player who doesn't like to break the fluff to use Ferrus Manus in a 'Post Istvaan' battle, being able to claim that it is a degenerating clone of the primarch created by Autek Mor. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323941 Share on other sites More sharing options...
Kol Saresk Posted March 2, 2016 Share Posted March 2, 2016 Bodt: If it has the Emperors genewrights seal, it is pre-heresy. Could it be a genetic sample from the Primarch project which saw the creatin of Primarchs and Astartes? A back-up to the genetic materials on Terra? Mor is looking for a way to clone Ferrus Mannus As odd as it may sound, I actually like having a hint that perhaps Autek Mor Can clone Ferrus Manus. Not for the lore as it cheapens the tragedy of his death, but that it allows an Iron hands Player who doesn't like to break the fluff to use Ferrus Manus in a 'Post Istvaan' battle, being able to claim that it is a degenerating clone of the primarch created by Autek Mor. Considering the Iron Hands IA article already says that even ten thousand years later when the Heresy is the almost-forgotten memory of a bad fart, there are rumors of the Iron Hands trying to resurrect their Primarch during the Heresy by replacing his head, cloning him and etc, it wouldn't cheapen the background imho. In fact, it'd be nice to see those little pieces pop up so we can see how those rumors were created. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323949 Share on other sites More sharing options...
God-Potato of Mankind Posted March 2, 2016 Share Posted March 2, 2016 Why would Mor want to clone him though, they famously didn't get along. He wasn't called to Istvaan and he declines to join with Meduson. He's almost a Blackshield, in everything but name. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323959 Share on other sites More sharing options...
Dantay VI Posted March 2, 2016 Share Posted March 2, 2016 Well IF it was a means to clone a primarch, would it not be just as well to steal it away from the traitors and deny them the use of it, as much as not to use it yourselves. Also maybe he is doing a Corax and wants to use the technology to increase the size of his black shield contingent or remake the Iron Hands. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323967 Share on other sites More sharing options...
GhostMalone Posted March 2, 2016 Share Posted March 2, 2016 But he could control the power of a primarch in his arsenal imagine a clone of ferrus bound by mental capacitors binding him to auteks will Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323968 Share on other sites More sharing options...
Kol Saresk Posted March 2, 2016 Share Posted March 2, 2016 The other thing to consider is that just because it is a clone of Ferrus, it doesn't mean it will act like Ferrus, even if it has the original's memories. In fact, I'd hazard the only reason the clones Fabius has created have Ferrus' memories is because the Traitors took his head, and by extension, his brain. Besides, could you imagine an army of Primarchs? Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4323983 Share on other sites More sharing options...
Sandlemad Posted March 2, 2016 Share Posted March 2, 2016 Its probably whatever technology the World Eaters had been using to push the limit on how fast a legionary can be created. IIRC, Its been mentioned in almost every FW book that statistically, when compared to normal human-to-legionary transformation time, the World Eaters casualty figures would've rendered them extinct but they have access to some technology that allows them to keep pace with their losses. Its heavily implied in the 40K universe, Krieg Guardsmen are created the same way, but from test tube to adulthood in a very short time. Just a shot in the dark though. If I was Mor, I would look for a magic formula to grow legionaries. Between that and the Iron Hands brutal doctrine, Im wondering if we won't see thousands of brainwashed, growth accelerated iron hands grinding across the traitor lines in the next few book. Whatever they were doing during the great crusade, they're doing it x10 in the heresy. In Retribution, Mor faces off against a few thousand WE legionaries but also eleven thousand half-trained WE inductees, made in months, not years. Basically after Istvaan some WE apothecaries returned to Bodt with mad flesh-science learned from the Emperor's Children and presumably the casket NoLats_McGee mentioned. They set to work on the planet's Mad Max-style population and went wild with recruitment. Seeing as how the FW books have mentioned all the legions ramping up astartes production, even if the WE are the standout example, I'd say Mor is up to something more sinister. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4324014 Share on other sites More sharing options...
Charlo Posted March 2, 2016 Share Posted March 2, 2016 I hope he makes an army of cyborg abominations :D Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4324065 Share on other sites More sharing options...
m_r_parker Posted March 2, 2016 Share Posted March 2, 2016 This question shall never be answered. It's just a story hook This is why I love Alan Bligh writing this series, he drops these little gems in there with absolutely no explanation and allows everyone to speculate what it could mean. Plus he has this annoying habit of vaguely answering questions with a glint in his eye, making you think you've hit upon the right answer but leaving you doubting that maybe he does that regardless of what gets put in front of him... Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4324068 Share on other sites More sharing options...
God-Potato of Mankind Posted March 2, 2016 Share Posted March 2, 2016 I doubt they can re-rereate Primarchs anyway. Isn't it pretty solid cannon the Emperor wove in some sorcery or otherwise factored the warp into their creation? Having the casket and pure science probably won't yield a Primarch. Lots of mega-legionaries though? Maybe. Also the World Eaters only made it possible by using the surgery-sorcery of the Emperor's Children. I doubt the Mor will be so keen to use Bile's methods. Link to comment https://bolterandchainsword.com/topic/319900-autek-mors-secret-treasure-massive-spoilers/#findComment-4324096 Share on other sites More sharing options...
