White base paints
hi all
im after peoples experiences using different brands of white paint to use as a base coat (brushed on)
Im painting a small white scars force and for my world eaters ive used Ulthuan Grey as a base which works well with the blue but looking for a more purer white base coat
Ive heard bad stories about ceramite white and never used Vallejo model colour or P3 whites before
Has anyone tried scale 75 paints?
Cheers
Dai
https://bolterandchainsword.com/topic/319921-white-base-paints/
base coating with white will not give you any margin for highlighting in terms of colour. It is common practice to base coat with a slightly darker colour than white to build up highlights towards white, or ofcourse base coat white and then shade down.
If you were airbrushing I would suggest Vallejo model air colours, they are very smooth and pretty good to airbrush straight out of the bottle:
Undercoat: Surface primer white 73.601
base coat: USAF light grey 71.121
highlight: white 71.001
If you want brush on I suggest P3 paints, they are very smooth and use liquid pigments, way better than GW ceramite white and vallejo whites that tend to be thick and separating. So I suggest:
base coat: P3 Menoth White Base
hightlight: P3 Menoth White Highlight
if you just work with the paint a bit; add some acrylic medium, toss in a agitator and shake vigorously then yes, you can make GW whites a bit better, but the much smaller pigments in VMA colours and the liquid pigments of P3 whites give smoother surfaces, which is more important when painting white when glazing or shading since grainy/bumpy surface shows on white compared to other colours.
Sol_Invictus: no stories, my own experience from painting white with a variety of paint makers
Halfords do a good white plastic primer - it's a spray can, though, so if you really need to brush it on you're a bit screwed.
On the plus side you get a really smooth, very white matt surface to paint over.
On the downside, it's a spraycan.
http://www.halfords.com/motoring/paints-body-repair/car-spray-paints/halfords-plastic-primer-spray
I was referencing the OPs comment about "bad stories" not anything you said. I do thin it a bit for my purposes but for a basecoat I would think the thickness would provide good coverage.
