Imperial Navy Avenger Strike Fighter
Spellscape
I personally like slapping autocannons on mine for those enemies where two S7 shots are better than one S9 one. The main argument against extra weapons is that you'll always be snap-firing at least one weapon if you add the wing guns.
My argument is that snap-firing one gun is still firing it, and you're also firing at least one extra at full BS over not having them at all.
That and the Avenger relies on killing the things that threaten it before they can kill it, since its so fragile. Needs a lot of alpha for that.
I don't usually add anything to my avenger's load out. Although it is relatively cheap, it is pretty fragile. However, there is definitely merit to what Miko says. The autocannons fit a good middle of the road versatile gun, and it does maximize the flyer shooting rules.
