Alpha Legion help
hi, so after messing around with the B@C box and using some other mk 4 models i had lying around ive put together the following , having three kids and other shizzle to get on with in my life i wont be adding anything for a while, i have some rhinos lying around but not much else i could use so im trying to stick with what i have , ive also went with alpha legion as the fluff is just quality.
so
Alpharius (i like the conversion and when its eventually painted ill post it but its made from captain karl,deathwatch termie and cataphracti bits for those interested)
Dynat
moritat with jump pack B@C Conversion
legion champion (model is cool )
B@C Praetor in Term armour
Chaplain
librarian
5 x Cataphracti
2 x 10 marine veteran tac squads , 1 with 2x heavy bolters and 1 2x olasma guns
recon squad (scout models with sniper rifles)
x5 marine support squad with either plasma/melta/flamer havent decided which yet
x 5 marine head hunter squad with a heavy bolter and all with combi bolters
destroyer squad with jump packs
1 x contemptor with twin dccw and grav gun hands
1 x mortis contmeptor with 2x kheres
5x marine heavy support squad 4x ML sgt with a PF and ocmbi weapon (no parts to convert the last ML
and ive 3 guys sat randomly doing nowt so i thought maybe  a PA Command squad/body guard
i can tweak the weapons for  anything except volkite and grav .
any help just getting all the bases covered , my plan is to always run infiltrate and pride of the legion.
my douchebag mate is running a 40k list using tyrants legion rules but as ultrmar auxilia , he has a bane blade, yippie !
any help much appreciated
https://bolterandchainsword.com/topic/320292-alpha-legion-help/
Hi, i'm played a few times my Alpha Legion. Igot the most Models like you.
So thats my idea for a 2000 Point list.
++ Legiones Astartes: Crusade Army List (Age of Darkness) (1998pts) ++
+ HQ +
Armillus Dynat
····Master of the Legion [Pride of the Legion]
Legion Centurion
[Artificer Armour, Combi-Weapon, Jump Pack, Refractor Field]
····Consul [saboteur]
+ Troops +
Legion Tactical Support Squad
[4x Legion Space Marines, Plasma Guns]
····Legion Sergeant
[Artificer Armour, Plasma Pistol, Power Dagger]
Legion Terminator Squad
[Cataphractii Terminator Armour with Combi-bolter and Power Weapon, Chainfist, 3x Combi-Weapon, 4x Legion Terminators, Plasma Blaster, 3x Power Fist]
····Legion Terminator Sergeant
[Combi-Weapon, Power Dagger]
Legion Veteran Tactical Squad
[2x Heavy Bolter and Suspensor Web, 9x Legion Veteran Space Marines, Legion Vexilla, Sniper]
····Legion Veteran Sergeant
[Artificer Armour, Power Dagger, Power Weapon]
[9x Legion Veteran Space Marines, Legion Vexilla, Melta Bombs, 2x Melta Gun, Tank Hunters]
····Legion Veteran Sergeant [Artificer Armour, Power Dagger, Power Weapon]
+ Elites +
Contemptor-Cortus Class Dreadnought Talon
····Cortus Dreadnought [Dreadnought Close Combat Weapon with inbuilt twin-linked bolter, Extra Armour, 2x Graviton Gun]
Contemptor-Mortis Dreadnought
[Extra Armour, Two Kheres Pattern Assault Cannons]
+ Heavy Support +
Legion Heavy Support Squad
[4x Legion Space Marines, Missile Launchers]
····Legion Sergeant [Artificer Armour, Exchange heavy weapon for a Nuncio-vox and Chainsword/Combat Blade]
Legion Whirlwind Scorpius
Legion Astartes [Traitor, XX: Alpha Legion]
The idea is dynat goes with the Melta verteran Squad. The Saboteur is hunting Vehicles. The HB Veteran is Middle Field Object Holder. The ML heavy Squad sitting at a Object in your Deployment Zone. The Cortus is hunting Vehicles. The Mortis is Anti infantery in the Middle Field. And termis are hunting other Termis. Ore Dreadnoughts. I hope it helps you a bit to decide.
Legion Centurion
As per the latest edition of the Legiones Astartes: Age of Darkness Legions, the Saboteur is no longer able to select a jump pack.
Also, IMHO, the Saboteur is only viable if he's kept as cheap as possible. That Artificer Armour and Refractor Field won't do him much good anyways, so I tend to run mine with only a Combi-Weapon at 95 pts. total.
