Ravens Flight - 1500pt - Decapitation Strike
"Raven's Flight"
So a quick list playing to what I feel are the strengths of the Raven Guard ROW and Legion Traits, also a completely different list to that of my Iron Warriors ;
Centurion - Delgatus
Artificer Armour, Jump Pack, Melta Bombs, Ravens Talons, Refractor Field
Moritat-Prime Kaedes Nex
Legion Tactical Squad
Chainswords and Bolt Pistols, Legion Drop Pod, Vexilla and Nuncio-Vox,
Sergeant has Artificer Armour, Melta Bombs and Power Weapon
Mor Deythan Squad (9 in total)
6x Combi Plasma, 3 Plasma
Dark Fury Assault Squad (9 in total)
Sergeant has Raven Talons and Melta Bombs
Legion Whirlwind Scorpius
Extra Armour
That all comes in at 1500, will get smashed against armour heavy armies, but plenty of Melta Bombs in the list as-well as Scorpius to strip HP's
Thoughts ?
You can make a point for the combi-plasma if you're tank hunting. With rending they'll do well against AV, especially against armoured ceramite. Which is what this list is lacking, AT. The Furies getting talons each helps with that too, S5 with rending on the charge will shred light-med AV.
Mechanized lists and/or artillery heavy lists will be an uphill battle. Beware augery scanners too.
At the moment the meta i'm facing;
Imperial Fist Gauntlet, Night Lord Troop Spam, Iron Hand Mechanized, Imperial Fist Troop Spam, Dark Angel Troop Spam (Big Heavy Support Squad)
I don't want to go too heavy on the AT as my Iron Warrior list is very heavy and this list is designed to be a polar opposite
It's not that you want to be heavy on AT, it's that you always want some. Which you do.
The plasma will do well against Gauntlet, breachers in that are one of the only things that can survive Mor Deythan with flamers. Keep your scorpius safe; it will likely be a key player against all those lists.
