Traitor-only options
Some Rites of War are marked as options of Traitors. Does it this mean it prohibits the taking of characters of whom you know they are either dead/loyalists at that point or are those simply directions given for narrative games and which side to take in a certain mission?
To ask more directly, is it possible to create a traitor version of a loyalist character and vice versa and play whichever Rite you like or is this explicitely prohibited by the ruleset?
Cheers.
https://bolterandchainsword.com/topic/320423-traitor-only-options/
Actually, I prefer something far less flattering, which would probably not make it past moderation :D
I jest ;)
Anyway, that is very disappointing. I have already started painting and fell in love with the fluff I created, so I will not go back on my choice, but I still feel a little bummed for being unable to use a significant part of my Legion :/
You could always say it's a pre HH EC army which would allow you to field both but obviously then you'll be gimping the RoW you can take which tbh is a good thing, it's either one or the other in terms of what you can have - like stated above, a side has to be chosen.
So I will simply have two lists. One with loyalists, which would be my primary, as they are supposed to be and one with 3rd Company RoW. I would need to come up fluff why they operate isolated and play them in games where sides do not matter or opponent's consent is given (or when playing against 40k, because I need every advantage I can get). Sounds fair?
To be fair, losing 3rd Company isn't what's bothering me though. It is not having Eidolon in my primary force. But well, some sacrifices must be made after all. I'll be damned before I play traitors in the fluff though :P
I'm confused.
Some Rites are listed as only being available to traitors' or loyalists' armies. Some characters are listed as being available only to traitors' or loyalists' armies. Why would that not be one and the same?
I am the one who was confused. I thought those were just 'suggestions' FW gave us for narrative games, not actual restrictions. Keep in mind, I do not own any red books yet and thus I need to work of second hand info.
Well, that is mildly annoying. But can I take both in a RoW that does not have said restriction, for example Eidolon and Rylanor? Or is there a rule against that as well?
There is no explicit rule against it. Usually the rule is "in instances in which an army must be declared Loyalist or Traitor". So if you're just playing a pick up game, you could Rylanor and Eidolon together. But if you and a friend are playing say, an Istvaan III campaign, then one of you must declare either Loyalist or Traitor, and that limits your options.
The RoWs work a little differently since some of them force you to "always declare" if you are a Loyalist or Traitor and in those instances, you have to follow it for "theme's sake".
Of course, house ruling and opponent consent will work many a wonder in removing that tiny restriction.
