Legatine Axes
NovaScotius
Hi All,
I'm putting together my first unit of Ultramarine Invictarus Suzerains, and I'm really struggling with the Legatine Axes. They're so flimsy that I'm worried that they'll break, and it's taken ages just to work out their warping as they're so delicate.
The more I look at them, the more that I'm certain that they were shoehorned into the Ultramarine background so that there would be a visual link between the 30k Invictarus Suzerains and the 40k Ultramarine Honour Guard models, who themselves only seem to have Axes because it was a big flat surface on which to put Ultramarine symbols.
Simply put, I've come to the conclusion that I'll be replacing the Legatine Axes with swords, and I wanted to use this post as a bit of a litmus test to establish if people would be alright with that, or whether it would cause issues. Obviously, I'll be pointing out that I'm using swords instead of axes at the start of any game with an opponent who hasn't played me before. I really can't see how it would be an issue with the Invictarus Suzerains themselves as the models are very distinctive, however, I'm a little more unsure about Characters who have been given a 'Legatine Axe (Sword)'.
I'd be seeking to have uniformity across the army and would most likely use the Sword in this set as my Legatine Axe; that component wouldn't appear anywhere else in my army, other than as a Legatine Axe...
https://www.games-workshop.com/en-GB/Ultramarines-Upgrades
Simply put, if I turned up with Invictarus Suzerains as well as a Character model with swords instead of axes, and explained this to you before the game started, how would you react?
Thanks
https://bolterandchainsword.com/topic/320624-legatine-axes/
I'd be fine with the explanation, but I can tell you right now they aren't that flimsy.
As long as you store your models well, in a foam case, the axes will be totally fine. Don't be overly worried about damaging them, the models feel pretty good once fully assembled. Also, the models and Axes are unique - Don't throw that away!
https://bolterandchainsword.com/topic/320624-legatine-axes/#findComment-4341788
Giving the Ultramarines a special unit focused on axes was just another of so many mistakes in GW's treatment of the Ultramarines over the years. Instead of giving them swords, which would have been much more appropriate both in terms of their theme (roman legion) as well as their character (versatility), they instead got axes, a more single-purpose "brutal" weapon which is otherwise associated with Khorne Berserkers, Space Wolves, Flesh Tearers or Orks.
I welcome anyone who replaces an Honour GUard or Invictarus Suzerain squad's axes with swords instead. I don't think anyone would mind such a modification, since legatine axes have their own unique mechanics anyway, and you are not just replacing power axes with power swords (which would then be a different item and could be confusing), but the downside is that you then do have to point it out to each new opponent that you did that.
https://bolterandchainsword.com/topic/320624-legatine-axes/#findComment-4342041
But Dark Angels are the sword Legion.
There are tons of sword legions.
But Night Lords are the only knife legion. B)
But honestly, axes make sense for the Ultramarines, especially given the XIII's obviously Roman links.
In Roman culture, there was the imagery of the fasces, which was an axe, surrounded by a bundle of rods. The symbol was used to show strength through unity. Something that makes total sense since the Ultramarines Legion derived their strength from the total unification of 500 worlds.
And with time, the fasces became a physical image carried by lictors, bodyguards, of magistrates to show their authority.
It wouldn't take a rocket scientist to imagine that Legatine Axes are based off of the Lictors' Fasces.
https://bolterandchainsword.com/topic/320624-legatine-axes/#findComment-4342165
From what I can glean, the bundled rods represented unity. The axe represented the authority to enact corporal punishment.
Add to this that the lictors were a purely civilian detail, with the fasces being ceremonial equipment. The Ultramarines Honour Guard could instead have been based on the praetorian guard, which was a military unit.
Imagine if the Ultramarines had a decorated "praetorian" unit with vertically crested helmets, instead of the "eagle-for-a-face" Honour Guard/Invictarus Suzerain models they have now.
https://bolterandchainsword.com/topic/320624-legatine-axes/#findComment-4342192
Breachers with swords. Problem solved.
https://bolterandchainsword.com/topic/320624-legatine-axes/#findComment-4342226
I like the eagle faces, but I'd like to point out Tyrannicide and I had the idea to use the World eater cheek guard helmets with longitudinal crests before the invictarus upgrade came out. It looked amazing
https://bolterandchainsword.com/topic/320624-legatine-axes/#findComment-4342349
Got any pictures or sketches?
Cause that sounds interesting.
https://bolterandchainsword.com/topic/320624-legatine-axes/#findComment-4342399
One word: Power dagger. Well, two words: Alpha Legion Power Dagger. Four words...
Anyways, there are only so many weapons to be shared among 18 legions. There should be a power axe legion, but the closest we come is the world eaters. There should be a maul legion, but there isn't. Ultramarines should favor the gladius style, but our most iconic guys don't.
https://bolterandchainsword.com/topic/320624-legatine-axes/#findComment-4342795
I know you're not a fan of the Tempest background but it does emphasise the Invictarii acting specifically as an honour guard and sign of authority for the Tetrarchs, tasked with being arbiters of law and order, rather than the usual crusading units. It variously says that the axes are an old Macraggian staff of office used to enact corporal punishment by heralds as well as Guilliman's custom design. The latter part is a bit silly but the former does make it very similar to a lictor's fasces in function, the duties of the wielders and (sort-of) appearance. Can't blame GW/FW for not wanting to have a literal fasces on their models.wacko.png
Personally I like seeing one of the Emperor's Children swinging an axe or a World Eater with a sword. It gets away from the reductive 'axe = barbarian' logic and makes the legions a bit less one-note in martial character. Can completely understand that this might rub folks the wrong way on the UM's star unique unit though.
https://bolterandchainsword.com/topic/320624-legatine-axes/#findComment-4342976
True but what I mean is that the Suzerains are a real centerpiece unit, the UM's popular all-stars, compared to the Locutarus or Fulmentarus termies.
I should add that I agree with the OP about why the axes originally showed up on the 40k honour guard but I like FW's retroactive explanation for their heritage and think the OP is going about this the right way in terms of consistency and modelling.
https://bolterandchainsword.com/topic/320624-legatine-axes/#findComment-4343011
An axe is more useful. Its not just a weapon but a tool. Against a foe with shields, an axe can be used to pull a shield down or a opponent out of his line allowing another member to strike his opponent.
For breachers or seige craft i think the axe theme is better.
An axe is more utilitarian than a sword, a sword is just good for killing.
https://bolterandchainsword.com/topic/320624-legatine-axes/#findComment-4343211
