Cactus Posted March 23, 2016 Share Posted March 23, 2016 I'm considering buying a Betrayal at Calth bundle to kick-start a Heresy era World Eaters force. I'm looking for some modelling tips before I pull the trigger so I came to ask the best. 1. Sarum pattern helmets. These look quite simple to convert using plastic Mk VII helmets, if they even need converting at all. Has anyone done this already with decent results? If I can pull it off I'll have a bunch of spare Mk II World Eaters helmets to use on future models. 2. Boltgun and bolt pistol and chainaxe. I want at least one large tactical squad loaded for bear but unlike our Emperor-Father they only have two arms each. The obvious solution is a boltgun and chainaxe in each hand with a holstered pistol but I don't want to repeat it 20 times. Are there any particularly good examples of boltguns and/or chainaxes maglocked or slung that I can pinch draw inspiration from to vary my poses? Link to comment https://bolterandchainsword.com/topic/320735-bolterpistolchainaxe-and-converting-sarum-pattern-helmets/ Share on other sites More sharing options...
sockwithaticket Posted March 23, 2016 Share Posted March 23, 2016 Chainaxe attached behind the back pack, can imagine there are some unsighted bands or grooves for it to slot into:http://images.dakkadakka.com/gallery/2014/8/8/636503_sm-.JPGhttp://images.dakkadakka.com/gallery/2014/8/11/637879_sm-.JPGhttp://images.dakkadakka.com/gallery/2014/8/11/637877_sm-.JPGIn addition to Forgeworld's chainaxes Anvil just released some. Most of them are gripped (various different hand positions and wrist tilts, which is a nice touch), but one of them is loose and there's a spare haft, so you could cut the head and neck off one of the hands and attach it to that if you like. Link to comment https://bolterandchainsword.com/topic/320735-bolterpistolchainaxe-and-converting-sarum-pattern-helmets/#findComment-4344458 Share on other sites More sharing options...
Brother Dallo Posted March 23, 2016 Share Posted March 23, 2016 If you haven't already seen his stuff, KrautScientist does some pretty awesome work. The entire thread is worth a read, but the heresy stuff starts roughly on page 76. http://www.bolterandchainsword.com/topic/284419-khornes-eternal-hunt-krautscientists-chaotic-wip-thread/page-76 Post 1897 is a good place to start with conversion inspiration for what you're trying to do. Hope this is of use. Dallo Link to comment https://bolterandchainsword.com/topic/320735-bolterpistolchainaxe-and-converting-sarum-pattern-helmets/#findComment-4344461 Share on other sites More sharing options...
Annatar Giftbringer Posted March 23, 2016 Share Posted March 23, 2016 I did some easy converting on my noise marine melee squad. They're armed with bolter, pistol and chainsword, but the process should be similar with axes. IIRC one has bolter in one hand, pistol in the other and sword hanging from belt, one has pistol and sword with bolter stuck under the backpack (took some filing) and... I think the last guy has bolter and sword, with holstered pistol. Basically, just do some swapping around with which weapons are in hand and which are holstered. Bolter or axe could be strapped to backpack, pistol holstered, etc. I'll try to post a couple photos tomorrow or Friday. Link to comment https://bolterandchainsword.com/topic/320735-bolterpistolchainaxe-and-converting-sarum-pattern-helmets/#findComment-4344539 Share on other sites More sharing options...
Cactus Posted March 23, 2016 Author Share Posted March 23, 2016 In addition to Forgeworld's chainaxes Anvil just released some. Most of them are gripped (various different hand positions and wrist tilts, which is a nice touch), but one of them is loose and there's a spare haft, so you could cut the head and neck off one of the hands and attach it to that if you like. Fantastic! I hadn't noticed those new axes and I like them for all the reasons you mention. If you haven't already seen his stuff, KrautScientist does some pretty awesome work. The entire thread is worth a read, but the heresy stuff starts roughly on page 76. http://www.bolterandchainsword.com/topic/284419-khornes-eternal-hunt-krautscientists-chaotic-wip-thread/page-76 Post 1897 is a good place to start with conversion inspiration for what you're trying to do. Hope this is of use. Dallo Thanks for the link. I've had a quick skim through the last few pages and I like what I saw. I'll go back for a proper look later. I did some easy converting on my noise marine melee squad. They're armed with bolter, pistol and chainsword, but the process should be similar with axes. IIRC one has bolter in one hand, pistol in the other and sword hanging from belt, one has pistol and sword with bolter stuck under the backpack (took some filing) and... I think the last guy has bolter and sword, with holstered pistol. Basically, just do some swapping around with which weapons are in hand and which are holstered. Bolter or axe could be strapped to backpack, pistol holstered, etc. I'll try to post a couple photos tomorrow or Friday. Pictures would be great, thank you. I'd forgotten about tucking things under/alongside the backpacks to conceal the join. A few of those are just the kind of variation I'm after. Link to comment https://bolterandchainsword.com/topic/320735-bolterpistolchainaxe-and-converting-sarum-pattern-helmets/#findComment-4344583 Share on other sites More sharing options...
Grotsmasha Posted March 24, 2016 Share Posted March 24, 2016 On my phone, so linking is a little harder, but search (via Google) Gawain Veteris, he did a series covering converting mkII-mkV from GW plastics. Cheers, Jono http://www.bolterandchainsword.com/topic/262448-heresy-era-armour-tutorials-invictarii-helmets/ Link to comment https://bolterandchainsword.com/topic/320735-bolterpistolchainaxe-and-converting-sarum-pattern-helmets/#findComment-4344785 Share on other sites More sharing options...
Annatar Giftbringer Posted March 24, 2016 Share Posted March 24, 2016 Ok, here goes. Taking these photos also reminded me that these guys aren't quite finished yet, need to fix that :) http://i1016.photobucket.com/albums/af282/Annatar_Giftbringer/Emperors%20children/76BA0BE4-722C-47AD-B814-3F78AA57D03A_zpsz4p9zo3t.jpg http://i1016.photobucket.com/albums/af282/Annatar_Giftbringer/Emperors%20children/14E1DF43-331B-4B89-A4C0-BFC6A1EA6BFE_zps5whr9hga.jpg Also, as a bonus, here's a dark vengeance model and an aspiring champion, both triple-wielding: http://i1016.photobucket.com/albums/af282/Annatar_Giftbringer/Emperors%20children/A0FF1BD3-393B-473A-AB5C-340E2A68F570_zpsqkad5zu0.jpg http://i1016.photobucket.com/albums/af282/Annatar_Giftbringer/Emperors%20children/22AA7BD6-9AAA-400A-82B0-C9712F6529CC_zpsz7aymq9u.jpg Link to comment https://bolterandchainsword.com/topic/320735-bolterpistolchainaxe-and-converting-sarum-pattern-helmets/#findComment-4345233 Share on other sites More sharing options...
Cactus Posted March 31, 2016 Author Share Posted March 31, 2016 Wow, I like the unloaded bolter on the chosen's back. Thanks for the pictures, I'm reassured that simply gluing a third weapon to the back or thigh can get good results. Link to comment https://bolterandchainsword.com/topic/320735-bolterpistolchainaxe-and-converting-sarum-pattern-helmets/#findComment-4351173 Share on other sites More sharing options...
