Race Bannon Posted March 25, 2016 Share Posted March 25, 2016 Does anyone know the font used to create the number on the kneepad? Link to comment https://bolterandchainsword.com/topic/320792-rg-squad-number-font/ Share on other sites More sharing options...
Xenith Posted March 25, 2016 Share Posted March 25, 2016 Wingdings? Link to comment https://bolterandchainsword.com/topic/320792-rg-squad-number-font/#findComment-4346200 Share on other sites More sharing options...
Carlson793 Posted March 25, 2016 Share Posted March 25, 2016 Can you give a specific book reference. I'm seeing 2-3 between Horus Heresy, Imperial Armour, and Codex: Space Marines sources. The crossed out numbers common to Codex: Space Marines and generic Space Marine decal sheets is a GW proprietary one (but I've got a printable sheet in the Downloads as "Gothic Numbers"). The others... well, gimme a few hours. I need to finish up with work, then pull and clean up samples from various images to compare to known fonts. Link to comment https://bolterandchainsword.com/topic/320792-rg-squad-number-font/#findComment-4346252 Share on other sites More sharing options...
Race Bannon Posted March 26, 2016 Author Share Posted March 26, 2016 Carlson, those are it! I'm on a pad so will have to look at them another way, yet is the file layers for contrast? As in a black background? Going to need white numbers and the current GW decal sheet only gives certain numbers. Link to comment https://bolterandchainsword.com/topic/320792-rg-squad-number-font/#findComment-4346397 Share on other sites More sharing options...
Carlson793 Posted March 26, 2016 Share Posted March 26, 2016 Damn! Had to go back and look at those. Did those back before I was adding color layers. I'll see if I can get layered revisions up up in a bit. Edit: Actually, updates are awaiting mod approval. Black, Blue, Green, Red, White, and Yellow, for both numbers and color layers. Link to comment https://bolterandchainsword.com/topic/320792-rg-squad-number-font/#findComment-4346467 Share on other sites More sharing options...
Dosjetka Posted March 26, 2016 Share Posted March 26, 2016 What would we do without Carlson, eh? Good man, many thanks for your tireless efforts! :tu: Link to comment https://bolterandchainsword.com/topic/320792-rg-squad-number-font/#findComment-4346664 Share on other sites More sharing options...
JeffTibbetts Posted March 28, 2016 Share Posted March 28, 2016 Carlson, those are it! I'm on a pad so will have to look at them another way, yet is the file layers for contrast? As in a black background? Going to need white numbers and the current GW decal sheet only gives certain numbers. Race, I'm right there with you, but if you want to print white numbers you're going to need to do some work. Either ordering them custom, for which there are whole threads devoted to this and Carlson can probably point you in the right direction. I'm at work and can't be bothered to find them right now. Otherwise you'll have to print them on white paper with a thick black border and then paint over the edge to help them blend in a little. Link to comment https://bolterandchainsword.com/topic/320792-rg-squad-number-font/#findComment-4348544 Share on other sites More sharing options...
Race Bannon Posted March 29, 2016 Author Share Posted March 29, 2016 Or use clear paper and paint the surface white :P Either way, it's going to be a lot of black ink. I've researched custom decal makers and (so far) it has been cost prohibitive. Link to comment https://bolterandchainsword.com/topic/320792-rg-squad-number-font/#findComment-4348716 Share on other sites More sharing options...
JeffTibbetts Posted March 29, 2016 Share Posted March 29, 2016 That too, yeah. I'm happy with the ones I got from Fallout Hobbies, myself. I needed a bunch of chapter badges, though, not just numbers. Link to comment https://bolterandchainsword.com/topic/320792-rg-squad-number-font/#findComment-4348740 Share on other sites More sharing options...
