1850 Onslaught Iron Hands
Onslaught Detatchment
Right of War: The Head of the Gorgon
HQ
         Centurian (485 points)
                  Artificer Armour
                  Combi-Flamer
                  Consol: Praevian
                           2x Castellax Battle-Automata: Mauler Bolt Cannon
                           1x Darkfire Cannon
                           Enhanced Targeting Array
         Praetor (175 points)
                  Tartaros Terminator Armour
                  Combi-Melta
                  Power Axe
                  Iron Father
Troops
         10x Tactical Marines (160 points)
                  Nuncio-Vox
Elites
         Contemptor-Mortis  Dreadnought (180 points)
                  2x Kheres Assault Cannons
Heavy Support
         Medusa (155 points)
         Predator (200 points)
                  Executioner Plasma Cannon
                  Lascannons
                  Armoured Ceramite
                  Dozer Blade
                  Machine Spirit
                  Lascannons
                  Armoured Ceramite
                  Dozer Blade
                  Machine Spirit
         Whirlwind Scorpius (115 points)
I'm new to 30k, any feed back would be greatly appreciated
https://bolterandchainsword.com/topic/320928-1850-onslaught-iron-hands/
I believe you also have to have consent to even use the alternative FoC, even without the addition of a RoW.
Couple of points from my limited experience using the 10th and the head of the gorgon RoW.
1) put your 10 man tactical squads in Rhinos, it gives mobility, protection and most importantly (via the RoW) they can outflank, leaving your precious scoring units in reserve for a late game objective grab.
2) the predators look expensive, you have 50 points of upgrades alone on each tank. I would assign them a specific role, ie stick with the executioner cannon (anti infantry) or go autocannon/lascannons (anti tank). Machine spirit is expensive, armoured ceramite is also wasted on such a light tank. In my experience predator chasis vehicles go down to side and rear armour shots. Save AC for land raider type vehicles.
3) personally, I don't think the iron father upgrade is worth the points. Unless you're going for the fluffy list..
4) two HQs at this points level is probably too much and will leave less points to spend on the rest of your army. You can take castellax in your elites slot (without the need for a cortex controller with HotG) for a slight reduction in the units efficiency. Although, T8 castellax are tough!
