Carrying Case Question
Guiltysparc
I am looking into cases for my heresy army.  My buddy has one of the new citadel cases and i like it quite a lot.  A legion army would fit pretty well inside of one since its marines and such.  My question is how well things like a spartan and dreadnought drop pods will fit in them.  I am guessing a spartan would fit but probably take up most of a tray with the accordian style foam.  I don't really have any idea how well a dreadpod would fit sitting on its side.  Any ideas/suggestions?
https://bolterandchainsword.com/topic/320970-carrying-case-question/
A Friend has them and he says they aren't suited for larger stuff. Its good for small/medium vehicles with very standard shapes but stuff like Pods, Spartans (Which are just big) would give you a hard time.
You're better off finding Pluck Foam Cases so that you can use to make your own shapes to fit your army and any non-standard shapes and forms it might have.
Would also let you maximize Storage/Space ratio.
For reference, if your pod, on its side, is taller than a Spartan / Baneblade, it'll have a hard time fitting in the bottom tray of the GW Foam. Additionally, since its egg shaped, unless the foam has sufficient give to let it sit flat when stowed, it might cause you some slight problems during transit since it'll be able to move around.
Do a bit more research, tbh :p
I have one of the Crusade cases, and I can pretty much confirm everything that Slips says. If you're planning on bringing anything much bigger than a Rhino, while not impossible, it can be difficult to fit in. Not impossible, but pretty hard. If you're transporting the same army constantly (I just grab whatever I need off my display and put it back when done, since I have multiple armies and am unwilling to buy multiple cases) pluck foam and other customizable setups are a much better option while being far cheaper.
Another option might be just to get a big Citadel case (if you're gonna get one of them anyways) and get replacement pluck foam with similar dimensions to the trays (I think you can get them on Amazon) and just swap them out.
One trick I have been known to use with big items (like Land Raiders, Drop Pods,Tyranid Monstrous Creatures et al) is to fit them into the bottom half of the tray and then flip the top half upside-down on top of them. It's not the most efficient use of space, but it'll work in a pinch.
For my next army I am going to do plastic cases, metal sheet and magnets under my models, weapons don't break off and they are ready to play as soon as you take the top off rather than getting everyone out setting up etc etc.
Look into it, it's cost effective too.
I have the big citadel one, it's great for infantry and basic tanks ~3hp (Predators, Lleman Russes etc) but anything large isn't ideal.
So I carry my Spartans in a box. Just a regular, cardboard storage box. I stick a sponge divider between each Spartan and carry it upright and it's fine.
I can't imagine the horror of trying to transport:
Baneblade variants
Fellblade Variants
Dreadclaw/Kharybdis
Knights
Titans
Any of these cannot be fit into a GW case unless you magnetise or bluetac them. They're just too big and oddly shaped.
Baneblade variants
Fellblade Variants
Dreadclaw/Kharybdis
Knights
Titans
I found an excellent case in gifts for geeks for this, manage to get my fell blade, Spartan, land raider, las vindi, deredeo, think, 2 preds and a las vindi in! Well worth £30 and it's a decent case
Baneblade variants
Fellblade Variants
Dreadclaw/Kharybdis
Knights
Titans
Link, good sir?
I use one of the Large new GW cases and it fits my 2k Thousand sons:
x40 space marine models on 32mm bases
x6 Terminators
x1 Contemptor Dreadnought
x2 Javelin Attack Speeders
x1 Sicaran Battle Tank
x1 Damoclese command Rhino
x1 Dreadclaw Drop pod and flight Stand
The dreadclaw is what takes up the most space, basically just leave 1 half of the case empty for the drop pod.
http://giftsforgeeks.org.uk/shop/-/product/908254837/build-your-own-tyrant-army-figure-case/
Choose your depth, I had 2 deeper ones and a shallower one, I was wrong, £41, but still amazing for the price imo. I magnetise sponsons anyway, saves so much space
Battlefoam has an option for custom foam layouts. They can be pricey but they have most of the shapes for GW and FW items already. If you really want something special though, they also have the option for truly custom trays where you trace on a piece of paper around the model to get the shape right and they'll laser cut the tray to match your shape. They also have sales every once in a while and their stacker boxes can take the place of cases without being super expensive. So what you spend on the trays you can save on the boxes. Or save even more money and just save the box from shipping and put trays inside that. Or just get one of the old GW plastic cases and toss the foam to put custom trays inside.
I am liking the KR case's website and system of building the trays.  It looks like i can get my whole planned army into one triple case for ~$250.  Does anyone know if the leviathans will fit in the contemptor trays?  I figured i'd send them an email asking, although i feel like i could just buy some pluck foam to make all the custom shapes...
pulled the trigger on the KR case after emailing back and forth them...their sales support is awesome, the guy took what i had put together for tray load out and my army list and gave his recommendation, which was a bit better/more efficient than what i had come up with.
