Sister themed Maelstrom objective marker help
Hey guys I need a bit of help here.  I purchased these nice metal pins and I want to turn them into objective markers 1-6 for Maelstrom games (my area plays Maelstrom a lot)
Here is a pic with a 40mm base included for scale.  My hope is to keep the objectives on the 40mm base.
http://i.imgur.com/hnxSZuu.jpg
Thanks for the help and purge on!
Are you asking how to number them differently for ease of use, or are you asking what to do with them in terms of themed objectives (things such as banners, relics, etc)?
If it's numbers you could add transfer fleurs in the space around the main pin: the number of transfers equals the number of the objective.
I was originally asking for numbering help but now that you mention it I'll listen to any and all suggestions biggrin.png
In that case the most important thing is a prominent indicator of the number each objective has, so the simpler the better in practice. It helps to be able to spot the number at a glance, and usually from overhead.
The best things I've seen are banners with numbers on both sides, themed bases with a number of objects on them related to the relevant number, or just large, numbered discs.
  • 2 weeks later...
