Bloody Legionnaire Posted April 12, 2016 Share Posted April 12, 2016 I'm running into issues building Heavy Bolter devs, it seems like the way the hands are placed on the Heavy bolter causes the shoulders to be too wide for the body. Anyone else have the same issues? I'm guessing I'm going to have to pick up some green stuff for the gaps... any other recommendations? Link to comment https://bolterandchainsword.com/topic/321388-building-hb-devs/ Share on other sites More sharing options...
Ciler Posted April 13, 2016 Share Posted April 13, 2016 Are you sure you use the proper arm for it. The diagram in the box will give you the relevant sprue number. I know I got it wrong for one of my graviton devs and it wouldn't fit properly but with the correct one, voila ! no problems. Link to comment https://bolterandchainsword.com/topic/321388-building-hb-devs/#findComment-4363690 Share on other sites More sharing options...
Bloody Legionnaire Posted April 13, 2016 Author Share Posted April 13, 2016 Are you sure you use the proper arm for it. The diagram in the box will give you the relevant sprue number. I know I got it wrong for one of my graviton devs and it wouldn't fit properly but with the correct one, voila ! no problems. I'm positive, I'll try to see if I can get a picture, but there is only one set of arms that will work with the HB. It'd be pretty hard to get them confuzzled. Link to comment https://bolterandchainsword.com/topic/321388-building-hb-devs/#findComment-4364009 Share on other sites More sharing options...
SickSix Posted April 13, 2016 Share Posted April 13, 2016 Yeah they don't fit perfect but the famously large shoulder pads will do a good job of hiding minor misalignment. Link to comment https://bolterandchainsword.com/topic/321388-building-hb-devs/#findComment-4364565 Share on other sites More sharing options...
AndrewChristlieb Posted April 14, 2016 Share Posted April 14, 2016 Wierd, never had a problem with that. I'd probably just split the difference between the shoulder joint and the wrist then greenstuff any noticeable issues. As SickSix mentions, the shoulder pads should cover most issues that might pop up there. Link to comment https://bolterandchainsword.com/topic/321388-building-hb-devs/#findComment-4364601 Share on other sites More sharing options...
Bloody Legionnaire Posted April 14, 2016 Author Share Posted April 14, 2016 Yeah they don't fit perfect but the famously large shoulder pads will do a good job of hiding minor misalignment. Yeah I figured I'd probably have to pick up some green stuff. Link to comment https://bolterandchainsword.com/topic/321388-building-hb-devs/#findComment-4364638 Share on other sites More sharing options...
Xenith Posted April 14, 2016 Share Posted April 14, 2016 Not to insult your intelligence, but the left arm needs to lock into the left wrist at a very specific location, which is sometimes gummed up when using plastic glue. Have you tried rotating the left armclockwise slightly, bringing closer to the body? Link to comment https://bolterandchainsword.com/topic/321388-building-hb-devs/#findComment-4365001 Share on other sites More sharing options...
